Which programmer is right for me?
Darel
Darel
Mountain Top, PA
'21 JT Rubi Sarge Green; '08 JK
Military
'21 JT Rubi, no real mods other than a winch, Genesis dual battery setup, and 35s on stock wheels / suspension.
Now that my warranty will be up in a year or so, I am looking at programmers. I have done a lot of reading but I'm having trouble putting together one unit that meets my needs. I don't need to go all nuts with the programming, just looking for the following:
- Turn off ASS
- Tire size programming (currently have an AEV mini where this is its' only function but I'm sure that got erased when I got the clutch recall done last week)
- Speaking of the clutch recall, while I haven't had any problems yet, I want to be able to prevent / reset the service transmission / limp home mode if/when it occurs. This one is important.
- Planning on installing proximity door handles at some point, would like to be able to enable them
- Possibly same functionality as a Pedal Commander or at least "stackable" with one? No plans on this yet just thinking down the road.
- Is there a unit that allows you to program the oil pump to always stay in high pressure mode? I know with my German cars they default to high, and solenoid-enabled into low, so you just unplug the solenoid. Stellantis is opposite (which is dumb because now the fail mode is low oil pressure).
I can't think of anything else I want to do with it, but if I do I'll update. Thanks for the advice. I guess what really throws the wrench into the works for me is the service transmission reset, and honestly if I can't get that then it's not really even worth me buying one since the rest is just window dressing for me.
Thanks!
thedeatons
James
Boise, ID
Wrangler JLURX & Gladiator JTMX
I use the following, and they are flawless.
Step 1
Autostop Eliminator
ZAutomotive SGW Extension cable
Step 2
Jscan App for iPhone
OBDLink MX+ Bluetooth dongle
ZAutomotive SGW Security Gateway Bypass Module
Step 3
Roar Pedal Throttle Delay Controller
I simply unplug and remove when I don't want anyone to know they are there.
These solutions are the most thorough I have found in my research. I have them on two '24 Jeeps, and have no regrets.
Darel
Darel
Mountain Top, PA
Military
Ok, so you can "stack" them. Does the JScan reset the clutch slip/limp home mode?
thedeatons
James
Boise, ID
Sorry I am not sure. The JScan manual is available to search, or you can DM them on FB.
