Lost1wing
- First Name
- Tim
- Dec 22, 2020
- 24
- 2,675
- 2,972
- West Georgia
- 2020 Jeep Gladiator Rubicon
- Occupation
- Retired AMT
Start with taking the ground off at either the fender or at the top plate on the main battery neg. If you take it off at the fender, you know you have both batteries disconnected. If you take it off at the top plate on the main neg, it is possible to take off the aux neg cable. Now you are left with holding it out of the way while you take the other cable off. No big deal, just be careful. If you leave these grounds unprotected with either positive cables still connected and touch them to ground, you may see some sparks. That would just be the car trying to energize the circuits. Leaving the grounds connected to the fender and at the top plate and reming the assy from the main neg post leaves you open to the fuse array going bad if a positive cable touches ground. Usually the 150amp N3. Now depending on the state of the Aux battery, you will see different indications of the failed fuse. A dead or very low voltage would give you what I believe the OP had. He correctedthe issue by moving the positive aux cable to the main positive. He shouldn't have to do that if the pcr was deactivated (f42) and N3 was good.
If the aux battery was fully charge with N3 bad, it would have been posible to start and drive but failures would soon arise.
I am the owner of a 2020 with the OEM batteries. With a late 2019 build date, that puts my batteries at 5 plus years.
