AUX Battery Replacement Experience and FYI
Gatorized
ME/NH
I’m still running the original batteries on a 11/2019 build JT… always on a maintainer when it sits more than a couple days. But am getting intermittent start/stop failures that reset with engine restart. So just a matter of time and I will be replacing both. Pushing 6 years on the OEM batteries is a long time!
Could be why I have few electrical bugs on Jeeps.....
SimonH
Simon
Germany
2022 Gladiator JT
Did you at least CHECK the main battery, and charge both and reset the IBS in the process?
Well
I got the car with 24 km on the clock, but it was parked 2 years in a show room.
Batteries were dead, so dealer changed the starter battery (main) directly before handing over it to me.
Aux battery took 6 weeks to get in Germany, as it was warranty, it had to be an original mopar battery (at least from their service warehouse)....
then it was installed, and I think they reset what ever was needed.
  • Like
Reactions: MT1
Great Offender
2021 Gladiator Sport S - MT
Bought used in 23 with 27K miles and the ESS never worked so I brought it to the dealer. After several trips they replaced the aux battery but it still never worked. I don't drive it much so I keep it on a tender when I remember. Fast forward, dead battery, and I decided to replace everything. Found that my dealer had broken something when changing the aux which led me to removing it from the bottom. Still rarely drive it and I have added an exterior Noco plug which now lets me plug it in easily. AC is always on because = South TX and trips are 2 miles or less, charges at 14.1 V, and the ESS works 2 or 3 times until it quits. I work from home so I just don't drive it enough and I quit worrying. Got almost 4 years out of the main.
Sandman 4x4
Kissimmee, Florida
2024 Gladiator Sport S
Retired. Beach bum.
I'm more of a "leave, but pay attention" person. I watch battery voltage (checking while driving, and if it sits, I check voltage now and then to see if they need topped off with a BatteryMinder)
Now you are complicating things - and really done if one battery craps out - totally done. If one of the 12s goes to heck, you are normally still fine.
But batteries in series are another animal.
If I were doing anything - I'd simply get the largest capacity 112v batteries I could fit into the physical space.
Even tractors use multiple 12v batteries, not multiple 6 volt batteries.
That’s a good point if one dies. But trailer tractors have used multiple 6v in series on one side, then parallel for 12v. Just to get all the amps possible, ever see a starter used to start a 900 ci diesel with 18:1 compression?
My tractors were a mix of Case and IH............. and I worked on customer tractors in my shop, Massy-Ferguson, JD, Case, IH and so on.
There was a funny episode of IRT where they couldn't get something started, and pulled a battery out, and held it upside-down over the battery terminals of the other equipment to get it started. I thought - you are CRAZY - but it worked.
Generally what they showed were all 12v arrays there.
Rglideride
Arkansas
2023 Gladiator Sahara
Well, well we'll. I purchased a 2022 Sahara with 41k miles on the odor, 30 days ago. The auto start stop Never has worked. I ASSUMED the previous owner had bypassed the system (which I actually appreciated) so I didn't question it. This morning, after 2k trouble free miles, our Gladiator wouldn't start. Thanks to the forum, and participants comments, I have a place to "start"!
