Rear end sag with a small load. Please help.
NC_Overland
Raleigh, NC
2020 JT Overland
The bulk of the weigh from that quad sits behind the axle line. The uneven load dissuasion will contribute to the sag. Teh load capacity is about ~1700 lbs and this will include gear and passengers. What's the quad ~700lbs?
Seems to me load distribution would be teh biggest contributor. Do you notice its riding on the bump stops?
That’s not a max tow. The payload is likely nowhere near 1700 lbs.
hakoda
SoCal
2022 Gladiator Sport S MaxTow
My maxtow's factory payload sticker says 1463#. 1700 seems unlikely to even be possible but maybe with soft tops and legit zero options it could get there.
NC_Overland
Raleigh, NC
2020 JT Overland
I can’t even tell if it has the non max tow pkg with his bumper covered up. They might be the really light duty springs.
AstroZombie
Arthur
Poway, CA
Tech Support
My research i could only find that Max tow does not give any significant increase to payload and is more for increased trailer weight. They will work against each other, more payload and lower tow capacity and visa versa. @ShadowsPapa am i mathing this correctly?
NC_Overland
Raleigh, NC
2020 JT Overland
Max tow has dedicated springs and the highest payload. I’m not sure how you are coming in with that result. The only thing that lowers it is the more options added to the vehicle. It’s up to 1700, but if you have a hard top and some other options it could be say 1600. That’s just one example. Many other Sports, Mojave’s, Rubicons, Overlands, etc have a payload barely over 1k lbs. IIRC mine was only 10xx because it’s fully loaded.
ChrisNLA
Louisiana
2022 JT Sport Max Tow
I don't have another Sport S to compare to, but mine with Max Tow stickers at 1,471 pounds of payload I believe. The Rubicon my buddy bought same day was just a shade over 1,000. I know that's not an even comparison (different models) but just throwing that out there.
According to the 2022 owners manual, the Max Tow has more tongue weight capacity than any other Gladiator package. 765 pounds vs the next closet at 700 pounds in the Rubicon.
So, is that indicative of the Max Tow having significant increase in payload? 🤷‍♂️
Perhaps not, considering 765 is 10% of 7650 pounds towing on the Max Tow, just as 700 is 10% of the 7000 pounds towing on the Rubicon. Numbers game.
Max tow the BASE version with no added options and so on is rated for a pretty hefty payload of something like 1700 pounds. Any and all options take away from that.
No, payload and towing don't work against each other - but tongue weight does count against payload so if you haul a heavy trailer and it's got a hefty tongue weight, it will drop the payload number down but since the max tow starts higher than the others anyway, it's still going to whomp the other versions of the JT
Bourget117
Eric
2026 Jeep Gladiator Sahara
My Sahara (overland) doesn’t even have over 1000. I was shocked to see it maxed out at 924 according to the door sticker. It’s got to be because of the springs and tires.
VA6489
Rob
Dahlgren Va
Mercedes E250 Bluetec
DoD
So I loaded my 2008 king quad in the bed of my gladiator. First of all I have a Roll n lock bed cover and it takes up sooooo much room towards the front. So I may sell the bed cover. Anyways, that’s not what this is about. But what I was more concerned with was my truck sagged so bad.
Any suggestions on a saggy booty on the gladiator? It’s a stock sport s.
I do not know why everyone is so surprised with they haul a close to max load that their suspension sags under the weight. The Gladiator is not a 3/4 or 1 ton Puckup it is more like a family station wagon with a big trunk.
You have a couple options.
1) Buy a 3/4 ton truck. Emply ride will be rough but the suspension will not sag with 7-800# in the bed.
2) Buy a trailer. Tractor Supply has little single axle trailers that will easily support the weight of the Quad and they are inexpensive.
3) Live it the fact you have put a heavy load in a light weight truck.
Sandman 4x4
Kissimmee, Florida
2024 Gladiator Sport S
Retired. Beach bum.
That’s because of the springs! The tires at at least good with just a P passenger rating for at least 2,000 lbs or more per tire, time 4 will be well over the GVWR. The reason why I believe is due to off road suspension articulation.
Bourget117
Eric
So some better springs and shocks should fix things?
Again, it's a heck of a lot more than just springs and tires. You can't build your way into more safety and payload. Sure, you can put in stiffer springs but that can actually have NEGATIVE effects in an emergency. I bet the load rating on the tires is more than adequate.
NO. You'll reduce sag, but not improve anything other than that. You can't build more payload into it., Wow. Please READ the dozens of explanations about it in these forums and read and understand the SAE testing these things go through.
Payload is NOT about what springs you have.
You can't fix that sticker number tossing parts at it. You bought the wrong truck.
