capercrew02
I find that the order you install the window matters on how easy it is to install. I slide the window in the top track, then install one sides vertical, then install the other sides vertical, starting with the top corner, and slowly rolling down into the track, then I do the main bottom strip, starting at one corner then rolling it in the groove to the other side, then finally the last two corner bottom tabs. If you do the top, then bottom, then sides there is too much friction to stretch it or position it side to side.
