Minnie2011
Accounting
Interesting. I am on my fourth service visit and been requesting an engine compression test for 2 days now. So far, no cooperation.
what other tests or repair attempts were made before the engine compression problem was identified?
When the computer update to the PCM that was released in mid-July did not resolve the issue, they started doing more tests and found the compression issue. I have not seen any of the paperwork on this current visit so am not sure what else they may have done during the past month that led to the engine replacement. Also, I have been told the replacement is a brand new completely assembled engine from the factory.
SJK
Miami, Florida
2025 Gladiator Rubicon
I am at the same point. My service dealer seems to be resisting the test to determine whether compression issue is the cause of my problem.
My regular symptoms are ESS needs service and sensation of misfiring engine. I have had 4 CEL lights over 3.5 months since purchase. Were your symptoms similar?
Minnie2011
Accounting
Before the PCM update was getting PO300 codes and CEL along with ESS lights/messages. After PCM, it was “pending” PO300 codes and ESS lights/messages. Had rough idle consistently throughout. Dealership confirmed engine was misfiring and in working with FCA technicians identified the compression issue. I would ask dealership to ensure they are talking to FCA technicians that have addressed this situation as it is a known problem. I would also ask your dealership to escalate this on the FCA customer service side. I know it is incredibly frustrating. Fortunately my dealership has been very helpful. Good luck.
Gijohn96
Washington State
Overland
Refinery guy
By the way,
Jeep Cares will do nothing for you while your vehicle is in the shop on an "active case" if your vehicle does not qualify for your state's lemon law yet.
Once it comes out of the shop, they will negotiate items for your "inconvenience".
I am more than inconvenienced when the shop has my rig more than I do and I haven't even made a payment on it yet.
AFMike
San Antonio, TX
2021 JT
Welp looks like I get to start this magical journey.
Build date: 11/19
Mileage when occurred: ESS @approx 8k, CEL/P0300 @ approx 9k
How many occurrences: ESS multiple, CEL/P0300 first time today
Exact codes: P0300
Issue ongoing?: Y
What has been done? Calling today for service appt
Issue resolved? N
SJK
Miami, Florida
I just got a call from my Service Manager. Reportedly, my Gladiator "passed" the compression test. But in doing the work, the mechanic noticed that lifters on the left side of the engine were "loose," and that new lifters would be installed. Additionally, another computer update to address these issues was being issued by FCA as of tomorrow, and would be installed on my Gladiator then. After all that and a test drive, my Gladiator should be available for a pickup on Saturday. I am hoping for the best. Stay tuned.
speedracer0481
Erik
Maryland
2020 Jeep Gladiator Overland (lemon law), 2021 JTR (on order!), 2012 Jeep Grand Cherokee Limited 5.7
Well, I just got a notification that the top end rebuild/replacement was unsuccessful. The truck immediately threw another P0300 code. Perhaps Jeep will do the right thing this time. 39 days in the shop, 53 days of ownership, 7 days of top-off fun times without a code and obvious misfires.
WvJeeper304
West Virginia
2018 Jeep Grand Cherokee, 2015 Volkswagen Golf TDI
Build date: 11/14/19 6 p.m
Mileage when occurred: ESS @approx 762 miles and CEL/P0300
How many occurrences: ESS multiple, CEL/P0300 twice
Exact codes: P0300
Issue ongoing?: Y
What has been done? Currently at the dealership for an extended stay
Issue resolved? N
Most of my engine is torn apart and sitting in the bed. Being told misfire is in the # 6 cylinder. Compression test shows left side of the motor 2,4,6 at 140,150,150 and right 1,3,5 at 160,165,167. At this point they aren’t sure why the big variance from the left to right side of the motor. They have pulled the oil control valves, checked the specs on the variable value timing and cam phaser alignment. The dealer is waiting for the next step/suggestion from FCA.
speedracer0481
Erik
Maryland
Lifters and rocker arms (both sides) didn't fix mine. I hope your results are better.
Not sure what the current spec is, but it used to be 10% was the max. Anything over that, you needed engine work. So a 165 minus 10% means the lowest acceptible is roughly 150.
WvJeeper304
West Virginia
I’m not sure either. That’s what I’ve read as well. I’m not sure what they’ll do next.
txGlad
nTX
2025 JTRX
ex-TIer
Date of Mfg: 11-19
MDH: 111822 505AA
Mileage when it first occurred: 461 miles
How many times has it occurred: 2
What exact codes did it throw: P0300
Is the issue on going? Yes
If so, what has been done to try to solve the issue? First visit "cleared code and test drove vehicle. Light did not come back on this time."
Was the issue ever fully resolved? Not yet
CEL and ESS
Anyone in the NE Dallas area with a recommended service department? One perhaps with experience with this issue?
SJK
Miami, Florida
Next step is computer update, and now a second update.
Third step is replacing engine parts such as lifters, rockers, etc..
So far, the only reported true fix I have read about here is a complete engine replacement.
I am just finishing 3rd step.
Sanders1976
Steve Sanders
Oklahoma
Build date: 11/19
Exact codes: P0300
Issue ongoing?: Y
Issue resolved? N
Does anyone have an exact count of how many gladiators on here have the misfire issue?
Sanders1976
Steve Sanders
Oklahoma
Oh I forgot to post my info
Built in nov. 2019
Purchased May 2020
P0300 code twice, 2400 miles
In the shop now for the last 44 days.
New fuel pump, fuel injectors, currently getting timing gears and cylinder heads.
