Silvertruck
Silvertruck
Birmingham Alabama
2020 JT Rubicon
It is because the gear teeth are thinner More teeth
Actually, its because the pinion head is smaller, with less teeth in contact with ring gear. Smaller the head, the more chance for teeth to shear off.
Gobi Gladi8or
Yuma, AZ
Agriculture
488’s and 35” Falkens. RPM’s in 7th & 8th @ 71 MPH.
What is your mpg in 8th gear at 71mph out of curiosity. I am going the same set up 4:88 and 35’s
Haley
Phoenix, AZ
2021 Gladiator Mojave, 1981 CJ8
Landscaping
488 gears on 35’s here. I’m getting 18.5 mpg
Mostly city
Based on screen readout or hand calcs? My screen says 18.2 but hand calcs tell me 16.3.
Deleted member 30519
I just got 5.13s on my M/T and I was @ 2500rpm in 5th gear @ 70mph on my way home from LBI. Running 38" tires.
itsdapk
Peak Sponsor (Level 2)
PK
Forked River,NJ
www.hamburgerssuperchargers.com
2021 Mojave , 2019 Ram
Sales Manager @ Hamburger's Superchargers
5.13s are best in my opinion. I hear many people with 4.88s wish they had done 5.13's . Not the other way around. If you are adding heavy accessories 5.13 will help on the acceleration side as well.
Wheelin98TJ
Devils Lake, MI
2021 Jeep Gladiator
Bean Counter
There are actually fewer teeth on the D44 5.13 ratio vs the 4.88 ratio.
D44 4.88 is 44 teeth on the ring and 9 teeth on the pinion.
D44 5.13 is 41 teeth on the ring and 8 on the pinion.
Smaller pinion does not always equal less tooth contact area.
Check out the link below. Scroll to where it says "Gear size & strength info". I realize most this info is about the 9" which is a unique axle, but look at the comparative data for the D60. The D60 5.13 ratio is stronger than a D60 4.88 ratio. The 5.13 ratio has a larger tooth contact surface area.
http://www.truehi9.com/gears2.html
Fastwake
Rocklin ca.
2020 Gladiator Sport S
Mileage mileage mileage. Buy a frickin Prius.
Fastwake
Rocklin ca.
It will take you 5 years to regain your $ in gas savings
The White Rabbit
Sweeny Texas
2021 Jeep Gladiator Mojave
Self Employed
I am having mine dealership installed and covered by warranty with mopar performance gear sets when I get mine the end of this month. Will be rolling on 38" patagonias and mamba m25's ordered them last night
What’s the estimate on that?
FloridaMan
Orlando
Jeep Gladiator Rubicon
Real Estate
Just received a quote from a dealership in Central Florida for a 4.88 Mopar re-gear for $3,240... I have a JT rubi 8 Speed Auto. That was about ~ $1,000 more than I was expecting. Believe it or not that is supposedly with a special discount they are offering me due to a misunderstanding when I bought the Jeep (Long Story). Is that what I should expect for a re-gear now or am I being fleeced?
LAGladiator
Dustin
Louisiana
W
Waaay too high.
