ALT2870
- Aug 2, 2023
- 10
- 602
- 553
- Glenwood Springs
- 2021 Jeep Gladiator Freedom
What is the hole spacing? Have a different disconnect switch.
I have the bulldog version and it has a plate with it to install approximately there, and comes with a 2 gauge "pigtail to go to the + on the battery. There are no instructions. It appears that you run the winch positive cable and negative cable to the switch, and the pigtail to the + on the battery. What grounds the winch then? Run another cable to the negative on the battery?I used a simple keyed battery cutoff switch. I fabbed the bracket from a piece of aluminum bar stock. It's attached with a pair of rivnuts using stainless steel hardware. I didn't like the look of bare aluminum, so I sprayed the bracket with some leftover crinkle finish gray spray paint. It works great and altogether, it was less than $50.
Plow and winch both ground to the IBS stud on the negative terminal.I have the bulldog version and it has a plate with it to install approximately there, and comes with a 2 gauge "pigtail to go to the + on the battery. There are no instructions. It appears that you run the winch positive cable and negative cable to the switch, and the pigtail to the + on the battery. What grounds the winch then? Run another cable to the negative on the battery?
