Alu-Cab Canopy Camper Roll Call
JeeperFIN
Jukka
Finland
2021 Jeep JT
Some progress with interior, simple wooden frame with leftover plywood pieces. Coated with raptor liner.
Probably after few trips i will see does this interior setup work or not 😁
Jeep Gladiator Alu-Cab Canopy Camper Roll Call 495CE66F-FAFE-4787-A898-949EBC8B3474
mquetel
Oregon Outback
2022 JT Rubicon diesel
I finally have my Webasto heater enclosure prototype complete and should have these into production very soon. What do you guys think?
Love it! By far the cleanest diesel heater option I've seen. My Dickinson has worked fine for the past couple winters but it doesn't keep up when temps are in the 20s or colder. I am seriously contemplating a conversion to this, once development is complete and I can accurately assess costs and conversion difficulty. It's a really thoughtful use of the camper's internal space, which was one of the big value propositions of the Dickinson heater in the first place.
Steven_B
Steven_B
Steven
Federal Way, WA
aroundthenw.com
2018 WK2, 2001 XJ, 1993 YJ, 2021 JT EcoDiesel
Digital Marketing Manager
813 Fabrication & Design
Rock Sponsor (Level 1)
Jeremy
Louisville, KY
www.813fabrication.com
PRICE DROP on our MOLLE and PACKOUT panels for the Alu-Cab campers. These work with or without the water tank as well as on the sides of the MODCap (mid-size only at the moment) depending on which brackets you need. Mix-and-match between the two for optimal storage or holding your Joolca HOTTAP water heater.
I've been adding some more products for the Alu-Cab also. Let me know if I can help out with your setup!
https://813fabrication.com/collections/alu-cab-camper-accessories
Wonkinator
SLC
2022 JTRD
I’m in the same space mquetel. The Dickinson works fine for us but I’d like more control and a thermostat so I can let it self regulate. With the Dickinson I have to hang upside down from the bed to turn it off when it gets too warm inside. The diesel heaters have really made big strides these last few years plus Jeremy’s products are top notch.
Wonkinator
SLC
2022 JTRD
Anyone else have issues/questions about the RedArc TVMS Systems? I’m NOT an electrician, but would like to add devices and figure out how to configure the iPhone app without having to reconfigure the entire system. I wish there was a RedArc User Group as helpful as this forum has been. (Maybe there is and I haven’t found it??).
DR.
Doug
Mojave Desert
2021 Gladiator JT370
There is a Facebook group I follow. Their recommendation when I was having some trouble was to call service in Australia. Just have to work with the time difference. The website will let you know the best time to call. I did and they were super helpful. The system seems far from intuitive, at least for me.
Jeremy
Louisville, KY
Agreed, I almost also ask for Andrew. Super nice guy and has spent over an hour on the phone with me when working on a previous RedVision install. I have not found a way to do changes without having to do a full reconfiguration. Seems I mentioned it to Andrew once and they may be working on a better way, but I am not 100% sure. What is even worse, I have multiple screens. Each screen is independent of the other, not chain linked, so I have to unhook each screen from the TVMS, program it with only one screen connected and repeat for each screen. That is really my only beef with the Redarc system. Otherwise I love it.
Jeremy
Louisville, KY
Thanks!! I am glad you like my stuff.
Wonkinator
SLC
2022 JTRD
I just have a few minor changes (adding Starlink mini, getting the six water tank levels off of my iPhone app since I don’t have a monitor on my single water tank, etc) but it scares me to have to go back in and reconfigure everything. I absolutely love the RedArc and it’s been rock solid but seems like documentation/manuals/training for non-electricians is lacking. Thanks for the update.
Jeremy
Louisville, KY
Something new I have been working on! Another great way to transport more gear. While it does block the side door, it can be set up to remove quickly if needed. I am also working on a hinged version. I have lower and upper brackets for this with the previous classic style canopy camper. Let me know what you think!! Available soon!
Jeep Gladiator Alu-Cab Canopy Camper Roll Call IMG_7844
Steven_B
Steven_B
Steven
Federal Way, WA
aroundthenw.com
I like it. During the winter, that door is locked all the time anyway since I add insulation for cold-weather camping. Now, if you could only make a dropdown table system using those mounting points like the Alu Cab customers get for the canopies.
