@californiajeeping
- Apr 1, 2020
- 16
- 958
- 1,012
- California
- 2022 Jeep Gladiator diesel, 1977 cj5 LS swapped
Love the in depth explanations. You can argue theory and how its supposed to operate all you want. It is a poor design adding complexity to a very simple system. There are countless people having issues with the failing little agm battery.
I will standby what has worked in practical application. Improved reliability by removing the harley sized motorcycle battery that fails and going to one large battery and disabling ess is a huge improvement. More consistent and higher flooat or charging voltage to all systems and the battery. No more dropping to 12.4 during ESS and it kicking the motor back on.
The only issue I have is with the smart alternator itself. If you run an air compressor in park even with the rpm at like 2000 rpm it shuts the smart alternator off in park and wont charge well. If you do it in neutral or have someone sit in the truck in D but stopped it charges perfectly and will hold up to the load.
So one way around it is to put the tcase in N and trans in drive but that is semi-sketchy.
It sucks when your airing up a paddleboard or tires and it lets the battery get down to 12.4v and wont charge.
Again the oem overcomplicating something very simple in the name of imaginary economy.
