Mojave front locker using Rubicon switch.
Temperance
Temperance
Washington
2020 Jeep Gladiator Mojave
Software Engineer
Does it have to be the OEM Z Locker or will the one for aftermarket lockers work?
It appears that the units are both functionally the same. The only difference is that the OEM plugs into an OEM locker and the aftermarket has a generic plug which you'll need to wire yourself.
JohnQ
2021 MOJAVE, 2018 GC Trailhawk, 1989 Jeep Comanche
Do you know if the eaton locker has an oem style plug? And will your harness plug into either one of the Z auto units? I think I need to do some more homework. Thank you for your help.
Temperance
Temperance
Washington
Software Engineer
It appears to use a plug that is similar to the Z-automotive aftermarket one. You will likely have to splice it yourself if the plugs aren't exactly the same.
Yes, both the Z-automotive OEM and aftermarket have the correct female plug for the factory wiring harness.
Mtpisgah
Paul
Upstate SC
2021 JTM, 2018 JLR
The Mojave front locker wiring harness uses the same gauge wires as the factory one so it'll support up to 8 amps. I believe that the Eaton locker uses less than 5 amps. You will however, need the Z Locker OEM from Z-Automotive. This works similarly to the locker module I made but it just senses voltage to the locker to provide the correct status.
So with the cable, dash switch, and an Eaton e locker, we are not replacing the Mojave axle, just adding to it, correct?
Temperance
Temperance
Washington
Software Engineer
Yes, although I went with an ARB locker which replaced the front open differential. The locker was installed and shimmed when new gears (5:13) were added to save on labor. Adding a locker requires drilling a hole for the wires or air tube. I drilled out where the factory Rubicon axle wires are routed. Otherwise the rest of the Mojave front axle is retained. You'll also need a locker controller that mimics the axle lock sensor if going with the Eaton or an air locker. I sell the air one on my site and Z-automotive sells the one for electric lockers. Although the one from Z-automotive can be used for an air locker as well but you'll have to manually turn the air compressor on.
Mtpisgah
Paul
Upstate SC
2021 JTM, 2018 JLR
Awesome. I am going with the e locker at my mechanic's recommendation. I already have a z-automotive harness on the way due to my rear locker sensor going bad. And I have another on the way to have as a spare for my wife's JLR. I need to pot her sensors if I can get time to do it so I will not need the sensor.
How did you seal the hole around the wire?
And thanks for figuring all of this out.
Escape.idiocracy
Rich
PNW
Jt
Hitchhiker
Temperance
Temperance
Washington
Software Engineer
The ARB locker came with all of the fittings and plumbing. It uses an NPT threaded adapter. Hopefully the electric locker has all of the hardware for routing the wiring through the differential housing.
Mtpisgah
Paul
Upstate SC
2021 JTM, 2018 JLR
@Temperance What axle shaft did you use when you added the locker on the front? RCV says their Max Tow shaft will work with the Mojave, but would love to get confirmation from someone who has done it.
Temperance
Temperance
Washington
Software Engineer
The factory axle shafts were reused for my ARB front locker install. I believe the Mojave and max tow have the same axle shafts front and rear, but don't quote me on that.
Mtpisgah
Paul
Upstate SC
2021 JTM, 2018 JLR
I thought you had to replace the axles shafts to install lockers. I guess it is good that you do not, it might save me a few dollars. Thanks.
Bulldog4xfour
Invader33
JL sahara
When using a Rubicon Locker switch in a Mojave is it possible to use the sway bar disconnect button to active a solenoid, or would it become a nonfunctional button?
Bulldog4xfour
Invader33
JL sahara
Depends on the spline count, if you use lockers with 32 splines you can reuse the OEM shafts, if you upgrade to 35 splines you need new axle shafts.
Temperance
Temperance
Washington
Software Engineer
The Rubicon sway bar button can be enabled using the same device that is used to enable both lockers. The wiring harness for the sway bar is missing on the Mojave. The sway bar module is contained in the sway bar. It reports the status and contains all of the logic for enabling and disabling it. Theoretically someone can engineer a custom module that would do something different. However, the dash will still report the button status as a sway bar.
Bulldog4xfour
Invader33
JL sahara
I actually bought a rubicon sway bar to put in my Mojave that I want to actuate with air, and I was hoping that I could use the sway bar button to active the solenoid. Sound like it wouldn’t be as simple as hooking two wire up to the button though.
