Battery/ESS question
PJM86
Paul
Westminster, Maryland
1986 Jeep CJ7, 2020 Jeep Gladiator
So, I put a battery charger on the main battery and charged it up. I also drove it today several 15-20 min trips and the ESS light is still on. I contacted my local dealer and I have an appointment to drop it off on Friday morning. Fingers crossed. I will post an update, but I am hopeful. Hoping it’s just a bad sensor or relay.
dguy535
San Jose, CA
2020 Granite Crystal Launch Edition, 2017 Dodge Durango, 2001 Porsche Boxster
Customer Service Manager
Likely will need the secondary battery replaced. My dealer replaced both of mine with VERY similar circumstances
cecaa850
South East TX.
You should treat these like a big diesel with dual batteries. If you have to replace one, you should replace them both.
PJM86
Paul
Dropped Jeep off this morning, turned out to be a bent door pin that was causing the can bus system to throw the stop start system out of whack. They fixed the issue and the light is off, and the system works again. Happy it was an easy fix.
PsyRN
Eric
Santa Rosa
2020 StingGray JTR, 2016 Bonneville T120 Black
so even with a faulty ESS battery, everything worked "fine"? I installed a winch this last weekend and thinks went haywire. tested the batteries and found the ESS battery was low, and my truck would not start and was doing all sorts of weird things. I disconnected the ESS battery and ran a jumper form N1 to N2 and things are fine., everything worked. I charged the ESS battery on a trickle charger and it doesn't like it. The truck starts shutting off after a minute again. Now I have to re-attach the jumper to bypass the ESS battery. I'm just wondering how your trucks worked, even with the ESS battery going bad.
whiteglad
Joe
Vegas
2022 Gladiator Mojave
When I bought my JT, it had been sitting on the lot for some months and the batteries were down. I had the ESS not available message on the cluster. The dealer put in a new aux. battery and everything is now fine.
