Hated Safety issue
Mrwoodmin
Tony
Vermont
Gladiator 2020
I absolutely hate the fact that my 2020 new to me Gladiator Overland will not move in forward or reverse if the door isn't closed. Sometimes when hooking ups trailer for example and I need to back 1 more inch I jump in but have to close the door to move an inch. It's a real
PITA. Any way to disable that feature?
MaximusTX
TX
A tazer can disable this.
Jeep Gladiator Hated Safety issue 1786112068841-z3
SummertimeCarl
Louisville, KY
2025 Gladiator High Tide - 41'
The seatbelt being on disables autopark. You can buy a $20 seatbelt extender on Amazon and the Jeep will think it's on even when it's not.
Have you tested that? If it works I'm doing it!
Only asking if it works because when my doors are off I can drive with no seat belt needed, so I thought the auto-park was more of a door-sensor issue than a seatbelt-sensor issue.
ChrisNLA
Louisiana
2022 JT Sport Max Tow
It's both.
If the door is open the truck isn't moving unless your seat belt is buckled. The truck wants to know that you are attached to the seat.
That way you don't get out and get run over / crushed by your own truck like that one actor did.
ChrisNLA
Louisiana
It's both.
Also, just when you think 'that wont happen to me' just remember, people like my fiance exist that left her van running for 13 hours at work the other day because she forgot to turn it off.
That's one reason why a lot of new vehicles have idle timers when in park 😂
BourbonRunner
Baltimore
Foole
Or, you know, just close the door and use the hitch zoom camera? With that camera, you should be able to get it right the first time.
Pretty sure that's not on every JT and especially not the ones with the smaller UConnect early on in the run.
JTdiRtyD
Wes
MN
'22 JTRD
Army vet, low-code dev
I also dislike this feature, however I will never disable it. Heres why:
A few years ago I was out on a mountain trail and needed to get out of the truck to check on the trailer. I was distracted by a few different things and wasn't paying enough attention to what I was doing, and I was too quick to put the truck in park and try to get out. I missed park and instead put the truck into reverse. I didn't even realize it wasn't in park until I got back in the truck. If it weren't for auto-park the truck would have started rolling backwards down the mountain, with the Mrs in the passenger seat. We had issues with the parking brake earlier this trip, so that was inoperable and therefor not engaged.
I felt like such a piece of shit. Never in my life had I been so careless. Even now thinking about it my stomach twists into a knot thinking about what might have happened had the truck not put itself into park. Ever since then I am very deliberate when going to park, and I always check the cluster for P.
JmattNYC
Jay
New York
2021 Gladiator
Stinger side cameras- you have the pre-models should be easy install
ChrisNLA
Louisiana
Unless you got an uneven ass driveway like mine and it seems like no matter where I stop the truck rolls out from under the ball 😂
Sometimes I'm just out there yanking on the trailer like eff it, its close enough - or if its close enough and I can't move the trailer I set the edge of the hitch on top of the ball then lift the trailer jack just a touch and get in the truck and bump it slightly to make it fall on the ball 😄
Alpine Warthog
Eric
Allegheny National Forest, PA
www.instagram.com
21 Gladiator, 98 XJ
Retired USAF Police Officer
I remember an Air Force Radio Maintenance Airman died when the driver accidently kicked the transfer case shifter into neutral. It rolled backwards and down the mountain almost 400 feet. She was ejected. This was in '06 I think. IIRC it was a 90's chevy 2500 4x4. That's why the transfer cases have detents to shift to and passed N.
Yes akot of people dint realize if you tap the plus button ths camera zooms in and down to show you the ball hitch
