Manual trans shifting into third
Tripp
Matthew
Georgia
2016 Kia Stinger 3.3tt 2020 Jeep Gladiator sport s manual transmission
I have had my gladiator for a couple months now. I frequently hit the hazard lights button when shifting into third. It drives me insane. I won’t notice tapping it at times, and will notice my hazard lights are on.
Anyone else have this problem? Maybe it’s just me🤣
FOX JT
Chesterfield, VA
24 JTRX
I saw the title and thought, "Finally! Someone else has the same issue." Then I actually read the post and, no, my problem is different. I probably have hit something while shifting but nothing to go blinky-blinky.
I occasionally have a hard shift into 3rd that started about a month ago around 30k miles. It just requires more effort than the other gears. I bought transmission fluid last week to drain and fill but it's just been too hot to perform the maintenance. Maybe next weekend.
Scott0700
Scott
Rexford NY
2023 JT Rubicon
Self Employed
Mine had a hard shift and grinding going into third when new. They tried repairing it. Wound up requiring a new transmission. Get it looked at before your warranty is up.
MWarren
Lakeland, Fl
2023 Jeep Gladiator Willys Sport
When I had my MT the same issue occurred with me. I gave up with it along with the clutch issues. In the past l always preferred the MT over the automatic. Now I'm good with the AT.
Flyboy2109
Fred
Washington
2023 Gladiator, 2004 CTS-V, 2001 Tahoe, 1990 Dakot
retired Pilot: USCG, Delta, Netjets
Yup, and I turn up the blower. too!
Zachattack50
Zach
West Michigan
2022 JT
Small business owner
Speaking from experience, (Ive had my trans out 4 times now) If it seems to hang up going into gears, Re adjusting your cables usually takes care of this. Its a fairly easy procedure to look up. Its recommended after the trans has been removed, but occasionally I will just check mine for good measure. The cable shift setup sucks, and we all know the factory clutch is trash. I would totally buy a AT if I did it over. I also have tagged the hazard button on 3rd gear shift too.
