Rain X fluid and Low Washer Fluid Sensor
Prescottmojave
Prescott,AZ
2022 Gladiator Mojave
49 years of driving, 5 jeeps, numerous trucks and cars. Never has an issue with using Rain-X. I never let the reservoir get lower than half way.
onewhippedpuppy
Wichita, KS
2021 Gladiator Mojave
Aerospace
Same here, I run the orange stuff year round. It’s fantastic to knock down light windshield frost in the winter. I top it off every oil change on every car I’ve owned for a LONG time.
Rocksalt
Illinois
2020 Jeep Gladiator Sport
I ran Rain-X washer fluid until last year .. clooged line...found out thanks to this site that others have had issues with it. Stopped using it i.n my reservoir. No issues.
TMGladOverHighAlt
Jerry
Idaho
22 Glad
Logger
Rain-X has silicone in it. It can coat the sensors on NICE cars. :)
TheTrailGeek
Murphy, NC
2020 Jeep Gladiator Rubicon - Gator
Coder
I had this happen in my Subaru and sat there and ran it till it was empty, then put in the cheap blue stuff and ran a bottle of that through it and it started working again fine after that. Only put the cheap blue stuff in now if I have to refill.
Labswine
Steven
West Chester, Pennsylvania
Retired Chemist
Acetone will remove rainx residue, if you want
Just be careful not to pump the acetone through anything after cleaning the tank. It might dissolve some washers/seals/ etc. The rubber seals and etc. they use can stand up to methanol but not acetone.
My dealership uses a washer fluid that is clear with no dyes in it. Can't find at any autoparts stores. They are all either yellow or blue. You spray and what doesn't hit your windshield and eventually drys, leaves the residual color behind. I HATE THAT :mad::mad::mad: I saw it when I had my white 2011 Grand Cherokee Overland...the drips on the hood would turn yellow or blue (or green if I happened to mix fluids :LOL: ) so those of you with white Gladiators take note...you can have yellow or blue residue on your trucks :(
Anyone know where I can get non-colored washer fluid? Now that my factory warranty is up (by time not mileage), I'm going elsewhere for oil changes, inspections, etc. so it'll be less expensive than stealership prices.
TroutFishingInAmerica
The Great Pacific Northwest
Mojave
Well, I put Rain-X in the truck a few months ago. Never heard of any problem until this thread, some have had problems and some haven't. So I did a search and WOW! this has been going on for sometime. Some people say it only effects certain manufacturers, Jeep being one of them. I syphoned the Rain-X out and flushed the tank, then ran the windshield and camera with just water until I was absolutely sure it was purged. I'm buying the cheap blue shit from now on, screw it man, not going to chance it when all you have to do is buy the cheap stuff to avoid possible problems. Thanks for the heads up! Appreciate it.
obrianmcc
Meridian, Idaho
2020 Gladiator Sport S
No sensor issues, but Rain X plugged my nozzles. It nice that you have to pull the hood insulator off to gain access .... Not
ZoMojave
MW
Sold
I'm buying the cheap blue shit from now on.
Yes. Cheap -20 blue washer fluid year-round. I even used it when I lived in Arizona and that's all I have been using for 45 years. Only a couple of clogged nozzles in hundreds of thousands of miles. Nothing that a safety pin can't fix!
marsbars
Washington
Gladiator Mojave
Just did a quick google search for clear windshield washer and Prestone makes clear along with some other companies. Can get on Amazon
Shopshirt
CenTex
22 Gladiator
I just had the clogged washer issue recently blew compressed air fixed it for one spray. Took it to the dealer and they did the same thing compressed air worked twice then stopped. Take it back a second time "hey we blew compressed air through the lines and that fixed it!" Worked twice clogged again. Nothing but factory washer fluid in it and whatever they topped it off with. :headbang:
Raven65
SC
2022 Jeep Gladiator Sport S
I've used the orange RainX fluid for years in other vehicles and never had any trouble. I had JUST filled up the reservoir in my Gladiator a few months ago when I came across a thread like this one... so I promptly siphoned most of it back out and pumped out the rest through the nozzles... then I flushed it with water... and then put the cheap blue stuff back in. I had also just put a coating of the new RainX "ceramic" (rolleyes) treatment on the windshield itself - which the blue fluid probably stripped right back off... but whatever. The main reason I liked RainX so much on previous vehicles (mainly sports cars with curved, steeply-raked windshields) is that the wind would just blow the rain off of it so well at highway speeds that you hardly ever even had to use the wipers. No so with the flat/upright windshield on the Gladiator, so it's no big deal that I chose to ditch it.
I still do the standard hand application Rain-X treatment on the windshield and it seems to hold up well (about 4-6 months) even using the standard blue stuff washer fluid.
