BumbleBee
- May 24, 2021
- 3
- 62
- 107
- North Central Ohio
- 2020 Gladiator Sport
- Occupation
- Mech Engineer
I have done many regears over the years, and have accumulated all the right tools including the bearing set pinion depth tool (save a ton of time). Personally I have had a couple of sets that were acceptable with stock shims, but not many. I will also say this, unless you are extremely tight, you won't have problems if they are a little off. These vehicles don't have enough HP and towing capacity to really strain the system (some will disagree). Crawling does put some strain (but not heat) on the gears, but if you pull a maneuver that could break a gear, you will break anyways in many situations.
Last advice,,, always pick one gear set lower than you think you want. IMHO
