AZCooWhip
- First Name
- Rick
- Jan 9, 2021
- 44
- 1,018
- 2,214
- N. Phoenix
- 2021 Gladiator
Cooper STT ProsWith what tire size? Just curious
37x13.5x17
The sweet spot for 4.10 is stock Rubi tires.4.10 w 35's should be right in the sweet spot...should be able to hold 8th at 2000rpm w 75-77mph
Not w a diesel, maybe w the crappy gas motorThe sweet spot for 4.10 is stock Rubi tires.
The guy you quoted has a gas Gladiator.Not w a diesel, maybe w the crappy gas motor
Bingo. 4.10s are mostly ok with 35s but they aren't the sweet spot by any means. I think things like wind resistance and overall weight of the truck also come into play. I have a 2 inch lift, a little tire poke, steel bumper, winch and a bed rack. 4.10 is close but not idea. The truck wants to be in 8th most of the time, hence the hunting back and forth between 7th and 8th but it's just a little bit outside of the sweet spot. It's close enough where I wouldn't spend a couple grand to re-gear, though.The sweet spot for 4.10 is stock Rubi tires.
Bingo, same thoughts here! I've wheeled on 35s and stock 4.10, no problems no hangups, plus highway trans shifting is still fine. After these KM3s wear out, then will go to 37s AND regear to 5.13 (or maybe 4.88) still deciding what's the best compromise.I wouldn't even consider 37s unless the truck was getting re-geared at the same time.
When I re-geared my JK the shop told me to not spend the money unless you do a 1+ ratio change... in my case I went from the dog 3.23s to 4.10 with 33s. That really woke the engine up some. Going to 5.13 is probably going to make a real difference on 37s.Bingo, same thoughts here! I've wheeled on 35s and stock 4.10, no problems no hangups, plus highway trans shifting is still fine. After these KM3s wear out, then will go to 37s AND regear to 5.13 (or maybe 4.88) still deciding what's the best compromise.
I have to agree with this logic, when I re-geared my XJ it was 3:54 I went 4:56 it actually put stock speedometer on with 34.5-35 mud tires slightly under speedometer with 33s. But could "break" traction with tires on pavement of sorts un-modded 4.0 or get out of the way pulling into traffic.When I re-geared my JK the shop told me to not spend the money unless you do a 1+ ratio change... in my case I went from the dog 3.23s to 4.10 with 33s. That really woke the engine up some. Going to 5.13 is probably going to make a real difference on 37s.
I'm back and forth about whether or not I should have jumped to 5.13s, My highway cruising RPM is perfect--exactly where I want it. I'd need to drive a similarly equipped 5.13 geared gladiator to know for sure. I just did a long road trip, and my all-highway, up a mountain, down a mountain mpg is 18.3. WIth MT 37s and a 3" lift, I don't think I'll ever get close to stock. It's the city driving that's still at a stubborn 16.7.I have to agree with this logic, when I re-geared my XJ it was 3:54 I went 4:56 it actually put stock speedometer on with 34.5-35 mud tires slightly under speedometer with 33s. But could "break" traction with tires on pavement of sorts un-modded 4.0 or get out of the way pulling into traffic.
A detail(s) that is forgot on running really low gears is tooth size on gears and heat build up. So if 4:88 works for you great, only you know what you want or need. A reason "Back in the day" many "up-sized" axles was the tooth size from D44's vs D60/70 and 14 bolt. Not just stronger axles shafts and tubes. Drive 25 miles then change of gear ratio from 3:55 to 4:56 /4:88 and drive same 25 miles, you would find a substantial difference in temperatures. (even after gear break in) The axles (center section) in my XJ ran quite a bit hotter after gear change. You wouldn't want to touch them after HWY driving for some distance especially the D30.I'm back and forth about whether or not I should have jumped to 5.13s, My highway cruising RPM is perfect--exactly where I want it. I'd need to drive a similarly equipped 5.13 geared gladiator to know for sure. I just did a long road trip, and my all-highway, up a mountain, down a mountain mpg is 18.3. WIth MT 37s and a 3" lift, I don't think I'll ever get close to stock. It's the city driving that's still at a stubborn 16.7.
