Would PPF on the paint matched fenders help? Will be off-roading and overlanding/camping
AwakenAdventure
Earth
I am considering putting PPF on the paint match fenders on my Mojave X. But given how gnarly off-roading can get (rocks, branch scrapes, etc) do you think PPF will be sufficient? I’m also considering doing the hood just to protect and preserve this car as long as I can.
Any advice you guys have is greatly appreciated. Thank you.
Bandit’s Lair
Southern California
2021 Gladiator Sport S
Paint Protective Film.
Ah. Well in answer to OP then: It depends really where on “Earth” you Intend on wheeling. For branches and the various cacti of the desert you’d need to do basically the entire sides of the jeep to achieve protection. Having said that rocks and trees leave pretty good gouges and rubs so it most won’t defend against that. Pin stripes are kinda part of it. If you’re super careful most of them will buff out with a good wash and wax. Never fails you’ll get into a situation where there’s going to be contact with the local flora/fauna. Depending on budget I wouldn’t apply PPF unless you’re really AR about your paint job. Way better places to put your cash.
GeneralMaximus
Las Vegas
JTM
self healing PPF will help prevent bushes and branches causing pinstripe scratches. Scraping against a rock wall? forget about it.
bleda2002
2021 JTR Firecracker Red
The front fenders are already fully ppf'd if they are painted unless it's changed but this was the case in 21 and 22. The rears have the little patches of ppf.
RockFrog
Kermit
Sims, NC
2021 Gladiator Mojave, 1982 CJ7
PPF really does help protect paint. Have it on my Mojave, hood, fenders, door hinges.
I would recommend!
loganjeeps
Austin
Atlanta, GA
24 JTR 6MT, 96 Chevy 3500 5MT, 89 XJ (project)
I've had PPF on two gladiators. My only regret was on my 2022 I only did the hood and fenders. My 2024 is fully covered. I'm not rubbing rock walls, and no it won't help that, but I pass by plenty of brush and branches and no pinstripes for me. I've had to replace the PPF on one rear fender once because it took a bad rock hit from the highway, but the PPF took the hit and saved the paint. A lot less than repainting a fender.
caryt
Cary
Wellington NV
Retired/ Build jeeps
Expel PPF is what I'm planing to use.
