Finally available! > 2020 Jeep Gladiator Accessories - Trailer Brake Controller - 82215652
MobileHomeboy
Georgia
1984 CJ 7, 2018 Ram 2500 Cummins, 2022 Power Wagon
Installed mine today. Thanks WXman for your input.
How did you modify the hole from the 12v to allow the etrailer “trailer brake“ cover to snap in? I have the same set up and the slot on the cover is at the top and the groove on the dash is on the left side.
jwilson2899
Front Royal, VA
System Engineer
On mine I made a small notch at the top to allow the cover to snap in. It would be covered if I ever returned it to stock. Some have filed the notch off the cover as well, but I preferred to keep it to make sure for whatever reason it never rotated.
JWest
Jim
Burlington North Carolina
Gladiator Rubicon LE, JLUR Bikini Pearl, JLUR Granite Crystal, JKU Golden Eagle
I took a knife and trimmed off the tab on the cover. Didn’t want to cut the dash panel. Worked out fine.
lobelsteve
GA
Gladiator Gator
Going with Curt Echo. No need for an install and I am a set it and forget it type of driver. And if I need to adjust settings, my phone is always plugged in and on the dash magnet.
MobileHomeboy
Georgia
Thanks!
Angler3
Ed
New york
2020 gladiator
dumb question, does it add to towing capabilities or is it an addition to safety when max towing . I have a sport s with max tow . I actually use the cigarette lighter and not sure if I’m willing to lose the option.
It's more a safety issue. The rules vary by state, but most require brakes on any trailer 3000 pounds or more.
I'm not willing to give up the 12v outlet. I waited for a long time to see what the mounting options would be for the factory brake controller. I finally gave up and ordered the Curt Spectrum. I got the controller and wiring harness from Amazon for $155. The controller arrived Monday and the harness should be here today.
KMal618
Keri
Cumberland, RI
2020 Jeep Gladiator Sport, 2014 Jeep Wrangler JKU
Does anyone have photos of the Curt 51170 installed? Does it take the place of the 12V or mount elsewhere? I’m trying to decide between the Curt and the Redarc. The controller knob on the Curt looks larger than the Redarc. Thanks!
The Curt has multiple mounting options. I saw a picture of it done, in one of the threads, and plan to mount it on the left side of the steering wheel. I believe it is also less expensive than the Redarc.
Angler3
Ed
New york
2020 gladiator
Thanks for the reply
cgflyer
Lorton, VA
2020 Gladiator Rubicon MT, 2013 Ford Focus ST
United States Coast Guard
In the video of the install on the red truck he said the dash lights " go crazy " when the brakes are activated without a trailer. Does this condition go away on it's own?
I do not have this issue. I just got a 5x8 dump trailer with 7 pin harness and no issues with dash lights.
cgflyer
Lorton, VA
MobileHomeboy
Georgia
Well....... I installed the Redarc over the weekend and went on the first drive with it installed. Something weird happened. I didn’t have a trailer hooked up, but the audio on my radio kept silencing every 3 seconds or so. It only silenced for about 1 second each time , but it happened continually with every form of input until I unplugged the redarc from the Jeep. What gives?
jwilson2899
Front Royal, VA
System Engineer
Weird, never seen or heard of that issue. What wire harness did you use for plugging it into the truck?
MobileHomeboy
Georgia
The one for the Dodge Ram. I switched the blue/black wires to make it work for the JT.
