Winch battery disconnect and circuit breaker?
red/green hawk
Moscow, ID
2020 JT Sport S with max tow package, 2008 Suburban LTZ
PACU Nurse
I have this one installed and hooked up to one of my aux switches to power on and off.
https://a.co/d/2MErWSN
It’s on the left with the red connector caps on top
I just hooked mine up yesterday. It's just kind of sitting there. How did you secure it?
KevinM60
Southern Cal
2023 Gladiator Mojave
CAD/CAM
Same thing. I just have it wedged in there to the left of my VoSwitch.
it’s not going anywhere. If I ever come up with a good bracket I’ll add that but I’m not worried about it.
Jeep Gladiator Winch battery disconnect and circuit breaker? IMG_2013
articcatbill
Pennsylvania
2024 Gladiator Rubicon
I just finished my install and used the CentralAK bracket with a disconnect switch, great solution. I was going to go with the solenoid install but it was heavy and looking for a good place to mount it. Decided to go with this solution and very happy with it, it is simple, will be dependable and all the connections are covered. The bracket was well made and powder coated.
Jeep Gladiator Winch battery disconnect and circuit breaker? PXL_20250105_170810622
fourfa
CA
22 JTRD + ACCC
Technically it’s 15 or 40 amp. 15 is more than plenty to switch a relay like this, if you want to save the 40 amp circuits for other things that might need it
KevinM60
Southern Cal
CAD/CAM
my Understanding is my aux switches have 2 ratings, either 15 or 45 amp. Which do I hook to?
What he said.
Schnelleee
Missouri
2022 JTR
Similar to the one shown above, I modelled and 3D Printed a mount for my cutoff switch. Then went back and added a spot to mount the switch for my under hood lights as well.
Jeep Gladiator Winch battery disconnect and circuit breaker? 20250627_112920
Jeep Gladiator Winch battery disconnect and circuit breaker? 20250712_100710
Jeep Gladiator Winch battery disconnect and circuit breaker? 20250712_211253
Jeep Gladiator Winch battery disconnect and circuit breaker? 20250712_100708
Nice - great place for the switch (both of 'em)
Schnelleee
Missouri
2022 JTR
I didn't like the "automatic" plunger to turn the hood lights on when open. Was finicky and not a great place to mount them. This puts the switches right next to the battery and has the available ground lugs needed for the hood lights
Yeah, short distance for power to the switch for the lights, as well as ground being right there almost next to it.
