Add 850w heavy duty cooling fan to 3.6L Gladiator that didn't come with it. ( no Tow Package or Max Tow )
LouisvEarlleJT
2023 JT Willys Earl
@BoomerSooner1994 I’m just planning on doing this to complete the “package” since I added the class IV hitch. Wanted a bigger alternator and since the fan is plug and play might as well do that too.
The springs on a max tow are stiffer for higher payload.
The towing capacity comes from the gears and wider axles mostly.
Are you making modification to increase towing capacity? If so, have you considered obtaining beefier rear spring coils? I spied on a JT with the Max Tow at a local dealership and the part numbers for the coils were 68506180AA and 68506182AA. Do you think there is much different in these and the stock JT Willys?
As explained in multiple threads out here - you can't change towing capacity or payload. You can improve the experience, or in some cases the fan and alternator are swapped for hot climate driving, but tossing parts in isn't going to increase any capacity.
The max tow springs are shorter than others, but have a dual-rate - a higher rate and a normal rate. I had them under my 2020 Overland and they really didn't help the squat that much. So I didn't put them under my 2022.
Was not impressed. They also aren't what gives you a higher payload - they simply support the weight in different ways.
Andrew
US
2023 JT Willys
USN
Do 4:10 gears really matter unless you’re going up a mountain and does 1.5” REALLY make that much of a difference?
LouisvEarlleJT
2023 JT Willys Earl
You wouldn’t think, but yes it does. That’s not to say a standard truck can’t move something, but to get the top rating that is what it took.
Still, 6000 lbs with the standard tow package is pretty good
Heck yes. Big differences. Like I said before - it's been covered ad nauseum in other threads.
It's not only about pulling it, getting it going, it's also about CONTROL of the load as well. And wind and semis passing you and emergency situations like having to make a quick turn, trailer sway, braking and other fun stuff.
Most companies take their trucks through a standard battery of checks and tests on extreme hills, among other things.
My 2011 Silverado had a nice wide footprint and you couldn't even tell when a big truck passed you with the wheelbase it had. Further, check the specs on that truck and an identical truck in every way except the gear ratio made a big change to the towing specs of the truck. That was the only difference - the gear ratio. Same engine, same transmission.
Yeah, you would think so. Been around enough trucks and towing and such, and seen the testing they go through, and personal experience - the width is a huge factor and gear ratio is a thing even with Chevy, Ford and others. It's physics. Remember, even Pontiac used to sell their vehicles based on "wide track" - low profile wide wheel base means stability and performance. Control.
People forget it's not only about making the thing roll down the highway, it's about other traffic, wind, emergencies, control.
I can tell my JTO is a narrow truck. It was obvious from the first tow. Horrible? No, but if it was cheap and easy to increase the footprint by that 1.5" I'd do it. Just not worth the hassle and cost.
I'd leave the gear ratio alone at this point because I run stock diameter tires (wider, but same diameter) so it's not a matter of it not pulling - and I like the mpg I get, but the width I'd change if it was cheap and easy.
Jobofly
Joe
Upstate NY
2019 JLU, 2022 JTM
Just received my 850 watt fan from Rubitrux. Shout out to them, they are awesome to deal with. I am curious, once i add this fan and decide to upgrade to the 240 amp alternator is there a way to update my vin to include the tow package?
Your profile vehicle lists a Max Tow Gladiator. Max Tow already incorporates everything in the lesser Trailer-Tow Package.
LouisvEarlleJT
2023 JT Willys Earl
If you had a dealer install all of it they might be able to add a note in the app (like mine says “dealer added packages-aux switches”) but most likely no
Jobofly
Joe
Upstate NY
2019 JLU, 2022 JTM
Just realized that I never updated it to my Mojave.
Ok, with that, I will add to what @LouisvEarlleJT said and say it is probably a no that they will officially add the sales code.
For them to officially add the sales code to your VIN, it would mean they would have to acknowlege you have a higher tow rating than what was certified with when it left the factory. I doubt they will do that even though you meet the engineering aspect of it now as they did not do the work.
sharpsicle
Tampa, FL / Milwaukee, WI
Just curious, what would be the reason to do this?
Often times people get things added to their VIN because of programming and retaining that change during updates. But there's nothing like that for the tow package, it's just a physical mod, so having that added to the VIN won't really do anything for you.
I'd say don't waste your time trying. Is there something I'm missing?
Jobofly
Joe
Upstate NY
2019 JLU, 2022 JTM
I know that it doesn’t change the 6000lb tow rating. I’m not trying to increase that because it is not possible. I was thinking for resale or trade in value.
I just plugged in to KBB a 22 Mojave with 19K miles with and without the tow package and it only list a $200 premium difference.
I do not think the juice is worth the squeeze trying to get the VIN updated with it even if possible.
