CP4 Fuel Pump EcoDiesel Recall
The SM is playing it safe and poorly paraphrasing the wording of the owners manual.
page 389
" . If you buy good quality fuel and follow the cold weather advice above, fuel conditioners should not be required in your vehicle. "
"Commercially available fuel additives are not necessary for the proper operation of your diesel engine. "
it doesn't say anything about warranty.
The use of "Should" is a suggestion not a requirement from a legal wording perspective.
It just says additives are not necessary. Which is different legally then saying don't use XYZ or must or shall use XYZ.
At the power plant. We had an 8 hour class on word meanings. Someone got confused between "shall" and "should" one time. Cost the plant a couple of bucks in fines from the gov't. Gov't regs are a bitch sometimes in trying to figure on what you can, and can not do.
StoneyBanks
Clay
Southern Cal
Jeep Gladiator
Consultant
Ok, so to sum things up...
  1. Add 1-2 oz of EDA (your choice) with each full-up.
  2. Don't mess with anything under the hood and wait for the recall... roughly August.
  3. Easy on the MOD's until post-recall.
  4. Make sure my AAA membership (100 mi towing) is up to date.
That about do it?
Bananaman
Sarge Green Sport S JTRD
Retarded...err... I mean Retired
I got the recall notice today and the bit about no fix available is a nice touch.
The failures I’ve seen on the CP4.2 are due to improper fuel filter changes and not priming / purging the fuel system.
That's why I just took mine in today for a fuel filter change. Let the dealer do it so it's documented.
I was also informed I had the tailgate recall. ?
Sandevino
North Texas
2023 Jeep Gladiator Rubicon
What’s this tail gate recall?
Bananaman
@Rusty PW mentioned it a few days ago. Something about Gladiators with the power lock tailgate. I didn't get into it much with the service advisor as I'm going to have them do it whenever the fuel pump is done.
RubiNewbCB
757, Coastal VA from the 810 Thumb of the Big Ol'
22 JTRD, 21JGCL, 07 Mustang GT, 05 Chebby Hoe, 90 Fox body stroked and poked393W
USN NSW Seabee (1994-2021Ret.) / Current status DoD PMC
There is a piece for the power lock in the tail gate getting replaced. When it fails. you can't open the tail gate.
t-bot
'22 JTRD; '15 BMW K1300S; '24 Husqvarna Svartpilen 401
I just got my notice today as well. Had a fuel filter on hand, and just changed oil at 15k, but was planning to change fuel filter at 20k miles because I've read air/purge during replacement is hard on the pumps. May try to change it as parts become available for the recall, just before I take it in for the swap.
Motopilot0311
Stu
Orlando, FL
2021 JTRD, 2019 KTM SuperDuke 1290R
Fabrication Operations manager themed entertainment industry
"When you know, you know homie!" ? Patrol order.
9 Line
SPOT...
Fuck these acronyms are bringin me back!
Salty LCpl Creed: SKATE -
Seek cover
Keep a low profile
Avoid chain of command
Take your time
Enjoy yourself
mystic330
B
2022 JTRD
Just got my recall letter today....
My VIN was not in the original list - but it is an early '22, so I already assumed it was affected anyway...
tick-toc , tick-toc. ?
22EcoDs
NY
Hurry up and wait
Tom C
Tom
2023 Jeep Gladiator High Altitude Diesel
I wonder if they will build my diesel JT with a good or recalled fuel pump?
