Driver's Door Electrical Connection
trader979
Gene
Little Silver, NJ
Jeep Gladiator
Financial Services
Yeah, I read that after I wrote this. I wish I would have known about the white plate not working before I went to the dealership, it would have made things a lot easier to navigate.
My OCD is getting the best of me. I still can’t figure out why the sleeve comes out of the notches. Is it during assembly or reassembly? Is the sleeve or the lever defective.
berb
AJ
Maryland
Teacher
I believe the white piece is not retracting back out when the connectors are disassembled. So it exposes the pins. It sounds like the male connectors are defective on some of our Jeeps.
trader979
Gene
Little Silver, NJ
Jeep Gladiator
Financial Services
So it looks like these connectors are made by yazaki. I ordered a male and female to do some testing. What I can see is that when the connector is pushed together, the lever rotates and the sleeve moves past the notch. During disassembly, the sleeve gets hung up and is not caught by the notch. Alsmost appears that gravity drops the sleeve and then pops into the notch as the lever is rotated. Have a call into the company and have not heard anything. I am determined to figure it out.
trader979
Gene
Little Silver, NJ
Jeep Gladiator
Financial Services
Well got my answer today. Confirmed with the supplier of the connector that the protective sleeve, officially called the male blade protector, is preset from the factory in the the “protect” position. Once the connectors are mated together, the protector then moves and remains in the pushed in position. The connector is not designed to move the blade protector back to the preset protect position during disassembly. The only way to move the protector back to the preset protect position is manually. Seems like jeep chose the wrong style connector for a multiple assembly/disassembly application.
Bent pins are not user error, it’s a connector used for the wrong application.
BAT
Blaine
Katy, TX
Hello there @NaughtyGeek
We certainly would like to see this be remedied to your satisfaction. Our team works hand in hand with our engineering and brand teams to report developing vehicle concerns in order to pursue further research. If you would like to open a case with our team, we would be happy to escalate your concerns to a specialist for further assistance alongside your dealer.
Kathryn
JeepCares
Hi @jonaandcaleb
We certainly would like to see you enjoying your Jeep, as well! If you intend to work with your dealer in the future, please do not hesitate to reach out to our team for additional support.
Kathryn
JeepCares
Hello, please know that our team is here to offer additional dealer support in the case of any future appointment you may have. Please send us a private message if you find that you would like to address this concern with your dealer.
Kathryn
JeepCares
Hello there, we certainly understand how this may be concerning. Please send our team a private message for assistance alongside your dealer in resolving any concerns you are facing with your door function.
Kathryn
JeepCares
It certainly would be nice if you all came up with a fix for this cause its a pain in the butt to deal with. I got the jeep to take doors off and have been trying so carefully to make sure to put these plugs back together with care (Which I shouldn't have to baby it that much). I just had me doors off and then putting them back on I again was ever so careful to make sure everything was reconnected carefully. All seemed to go fine lined up and reconnected but nope started having some issues. Pulled the plugs and seems like one of the passenger side pins somehow got out of line. I straightened it up best I could and hoping that all is going to continue to work well. But I should not have to go through with this every time I take off my doors
Vtur
Le
Norcal
JTOD
Electrical Foreman
I agreed. It's a complicated over engineered connector
JeepCares
JeepCares
Auburn Hills, MI
Jeep Family
Customer Care
If you plan to visit a dealer for this and need support from our team, send us a private message.
Kate
Jeep Cares
BAT
Blaine
Katy, TX
Kate
Jeep Cares
I have managed to fix it myself so far but really those plugs need to be changed. For someone who takes doors on and off a lot there could be a better solution
Musser717
Mark
Canonsburg, Pennsylvania
White Gladiator Overland, c300 DD
I finally had my appointment to get new connectors, good news and bad news.
Good News is the new connector works perfectly, the sleeve slide down right to the edge of the pins to protect them and I was able to easily put it back together.
Bad news is the dealership told me BOTH sides were in but only the passenger side was and I was to wait a little longer for the drivers side. Progress I suppose
My service advisor did say Chrysler knows why the pins were bent but wouldn’t go beyond saying that. I pressed and he just said “they know why they are getting bent” I told him say no more. Hopefully this becomes a service bulletin for everyone else having an issue.
jnack
Josh
CA
JTD
Does anyone know which pin specifically operates the power windows? Initially I was having an issue with both BSM and the power windows though after playing with the pins I was able to get the BSM back on but the power windows are still not functioning. If I knew which pain exactly it was I can focus my efforts on that one. Thanks in advance!
Kg4rrx
Fayetteville, GA
21 gladiator Rubicon
Atc
Do you have part numbers?
SnazzGlad
Chad
Illinois
2021 Jeep Gladiator Sport S
Looks like I must have a bent pin. Pretty sure my defrost doesn’t work on my drivers side mirror and the lock/unlock button doesn’t illuminate at night. But the power mirror and the lock button work just fine. I have an appointment next week for a new issue of burping up gas all over at fill ups. Ill see if they can check it out while it’s there.
Rocksalt
Illinois
2020 Jeep Gladiator Sport
my power mirrors not working.. musta bent a pin on passenger side as evidently that controls both mirrors.
I saw a JL video where the owner fixed the pin, but said to disconnect battery before doing so? Is this correct?
I suppose that makes sense in the event any of those wires are powered and you touch more than one pin while trying to straighten things.
