PuddleJumper
- First Name
- Cortlund
- Jan 17, 2024
- 68
- 2,540
- 3,373
- Alexandria, Virginia
- 23' JTM, 22' JTR, 22' F56S,
- Build Thread
- Link
- Occupation
- STACK Infrastructure Critical Operations Technician
- Vehicle Showcase
- 1
HD engine cooling - IE bigger, thicker Rad, bigger fan, (and a trans cooler to i believe)
4.10 gears - doesn't matter if you regear anyway
1in wider track - D44 widetrac has 10mm thicker tubes than the non widetrack. supposedly just rear, only the Mojave has thicker axle tubes on the front. Haven't found proof to this despite multiple articles saying so. I personally believe the front D44 on the Max, Rubi, and Mojave are 10mm thicker just like the rear. I've seen non widetracks break at the FAD, but not the big 3. And since they are longer they would have more leverage against them at said FAD, but they don't break, which would logically imply thicker tubes. I've talked with a Dana aftermarket rep and he couldn't confirm everything but after lengthy discussion we both agreed 98% that the Widetrack is 10mm thicker tubes front and rear. Couldn't get a Jeep Engineer to pick up the phone.
Tbh there's a few more things but your swapping em out anyway. The only reason I see for you to Max is to get the sticker in the door jam. You gonna go D60/80 eventually anyway, and so much more. There really isn't a factory component i can think of that your gonna need to stay to make your build work. I'd save the cash if your going that custom. More money for a Hemi swap too down the road. The platform at its core doesn't change excluding the deisel and Mojave (they have a different frame)
