Oracle Flush Mount Tail Lights Issues
JP_Oracle
Peak Sponsor (Level 2)
JP
ORACLE Lighting
21 JTR
Link to smoked third brake light replacement?
Thanks
Oh goodness, this is embarrassing...? I am back & forth alot between this forum and the JL forum & I am realizing I gave you incorrect info on this. The replacement we offer is for the JL & not the JT.
Sorry for the mix up! Is it Friday yet?!
Rockabillyroy
CA
JT
Thanks for the reply :)
Stojanowski
Tom
Temple
2019 Raptor
Bum
Halogen Mojave here...
Not having turn signal issue but the right flush tail light running feature isn't working... It comes in when brakes are applied. Have taken it apart and connections are tight and works. Then seems to go out again. Boxy stock lights are about to go on again
JP_Oracle
JP
ORACLE Lighting
21 JTR
Hey Tom,
Shoot an email with a picture showing the one side out and the other working to [email protected] and our CS team will get you set up with a replacement.
A&WsGladiator
Alejandro
2022 Gladiator
I just bought both the flush mount and the reverse bumper Oracle LEDs for my wife’s 2022 Gladiator. No led package just halogens. Both reverse lights come off and on two times only. Then I have to turn off the truck for them to come back on and again only two times. The right taillight goes off and only works when it feels like it. I really didn’t want to mess with the computer just to get the lights to work. Can anyone help with a solution? Thanks in advance.
RS3
Marshall, Illinois
22 JTRD on order, 2017 4runner TRD
Self Employed
I did finally receive my replacement passenger side tail light the other day. It took a while to get here but it did show up. Aside from the plastic housing breaking on the first one I have had no issues with mine. Went from the factory non LED tail lights to these with the use of the Tazer.
JP_Oracle
JP
ORACLE Lighting
21 JTR
PM'ing you to get this sorted!
Stryker6040
Michigan
Construction Engineer
Here my situation, gladiator was in wreck back in march 2022, body shops around here back up until june 2022, factory rear tail lights ( LED with BSM) were busted and have been on back order since march. body shop gave us back gladiator in july with all fixed except tail lights and said they were work, well yes until it rained. September 2022 still no eta on tail lights.
Purchased Oracle tail lights followed all install videos, at first got the bulb out, hyper flash on dash etc, did the reset with my tazer mini and got that to go away. now issue i am having is with BSM, everytime I start up it says BSM is disabled or faulty and needs to be serviced, took the factory ones out just like all the videos show and installed them in Oracles, how do I current this?
Thanks
sharpsicle
Tampa, FL / Milwaukee, WI
Thanks
That sounds like something other than an issue with the Oracle taillights. Perhaps an issue with the actual sensors being damaged in some way from the wreck. The Oracle tail lights don't do much with the sensors other than hold them.
Stryker6040
Michigan
Was not getting the BSM error until they were swapped over to the Oracle tail lights. This was the only part of the factory tails that was still working after the crash which busted off both outer lenses. With slowly lost the leds over time as the weather took its toll.
sharpsicle
You could check that the connectors are completely and fully seated on the sensors. But beyond that, it's all part of the Jeep's system, not Oracle's. You could try putting them back in the factory housings to confirm it.
JeffWithaJeep
Central FLA
JT Rubicon
IT
Mine did the same but my setup may be different. I also had the Oracle rear bumper lights and the Oracle flush mount lights. My jeep has the factory LED's. I used the plug n play harness that goes in between the rear tail lights connection and the bumper lights and it caused me to get the sensor out errors (even after doing the Tazer work around to get the tail light error to go away). Once I removed the plug n play harness the sensor light went away. So I just hard wired the bumper lights to my aux switch.
Haden
PA
JT Sport
Not sure if this will help anyone, but figured i would share my experience. I bought the lights without checking reviews first and than was loosing my mind while they shipped expecting issues. I don’t have led’s so I installed the extra part that came with the lights. Had taser, but never changed anything. Everything worked like a charm with no need for taser.
ckgjt
Murrieta Ca
2020 Jeep JT Max ToE
well stupid me..I should have done my due diligence before buying these..bought Both the flush lights and bumper lights, installed them last night and now have random flashing reverse lights and an ocassional left revers light on the tail lamp..bought the pnp harness thinking I would not be another victim but guess what..I am...500.00 for nice looking non functional lights..pretty pissed
JP_Oracle
JP
ORACLE Lighting
21 JTR
Shoot me a PM and we can work through it and get you working. There are a few workarounds for the truck shutting down the lights like this.
