Sound System Upgrade
ndesantis
Nicholas
New Jersey
Jeep Gladiator
Longshoreman
Now that I’ve been moving along with all the exterior upgrades i’m starting to transition to interior. The sound system that came stock in my 2025 gladiator is garbage.
Has anyone upgraded the sound system to something that makes a big enough difference worth doing? Also what kind of additional sound dampening did you do to alleviate the freedom covers additional road noise.
I’m thinking of doing a sub with the new speakers but not a fan of giving up my little bit of under seat storage in the back. I’ve read this is where almost all subwoofer boxes are housed.
Any info would be appreciated.
Chris O
Alabama
2025 Gadiator Rubicon
I added a Kicker HS10 self powered sub behind the rear seat. Many others have as well. It definitely makes an improvement, and it doesn’t take up any space. The stereo went from a complete embarrassment to a pleasant listen.
Jeep Gladiator Sound System Upgrade IMG_3683
Bandit’s Lair
Southern California
2021 Gladiator Sport S
Which audio did you have originally? Wondering how much of an improvement with the Alpine stuff.
BSW520!
Cleveland OH
2025 JT Willys Mojito / 2026 JLUR X Reign
Service Dept. Lead / Service Writer
If you don’t plan on amplifying your dash, knee and sound bar speakers in my experience it’s marginal improvement from stock.
You will gain a little more detail in the audio quality but still have little improvement in volume even if you go with lower impedance speakers.
I did sound deadening Material on the floors of my gladiators while doing the stereo systems, but didn’t bother with the doors, top etc. will probably add hot head headliner at some point though. It’s still a plastic and fiberglass laden interior.
To me and what I did was definitely worth the upgrade.
TCASSADY
Troy
Charles Town WV
2024 JT MOJAVE
Check out SEVEN TRAIL. they have a package that I installed in my '24 and it is AWESOME! did lose the storage though
Rouse912
Barry
hawaii
2025 JT Mojave
I am in the same boat. I want to add a single sub but do not want to give up the under seat space. I think I could survive with a box just taking up the underside of the 40% seat. I haven’t came across any decent boxes for that side. Yesterday I was looking at the idea of removing the plastic rear wall and making a new one out of 1/2 birch with the lower 10” being a sub box. Would then coat the thing in a liner of some kind for aesthetics and water resistance. I have Already tackled replacing the lower dash speakers and the roll bar speakers. I noticed some improved sound. Lower dash speakers seem like a big deal but was overall really easy, I took my time and it took me maybe 2 hours. I did have to slightly modify the passenger side 6” box where the speaker magnet sat on my choice of speakers but that was no biggy. I also polyfilled the enclosures. I have an amp that I wil be installing for the mids and highs. Just gotta pull the trigger on the pac controller. I’m installing the armor light floors this weekend and will be pre-running my amp lines while everything is out for that.
Bandit’s Lair
Southern California
Id like to look and see how the stock sub is in there first and see if there’s a way to trim to fit a 10”. Still be a shallow mount so not huge bass but it might be good for depth of range. Maybe after all my other projects get buttoned up.
Timoleon
Las Cruces, NM
2021 Gladiator Rubicon, 2021 Gladiator Overland
Tech
Hot heads make a difference. My 2021 JTR has the factory liner, My 2024 JL needed the Hot Heads, and it worked!
biodiesel
New Mexico
2015 Ram 1500 Ecodiesel
The sound system on my 2023 Gladiator is also garbage. The build sheet says, "ALPINE PREMIUM AUDIO SYSTEM". I was hoping that JL Audio, Kicker, or someone reputable made a complete drop-in system for the Jeep. I don't have the desire to piecemeal a system.
Rouse912
Barry
hawaii
2025 JT Mojave
I started with looking at that but ran into cost probably being more by the time is done. I could only find buying the factory sub box with the sub included for $200-$300. It’s a thin plastic box (could probably do a fiberglass coating to stiffen it up) and I couldn’t find any real dimensions to be able to determine what size speaker could possibly fit not counting if you have enough internal volume for it. You would have to also buy an all new factory rear wall that’s made to fit around the sub enclosure. Would give the cleanest factory look tho.
in my search I did find https://oemaudioplus.com/product/jeep-gladiator/ overall looked to be a great system, comes with a behind seat enclosure but the price tag was $3000. Wasn’t feasible for me as I already had the mids, highs, and amp from a previous jeep that got totaled.
Wheelin98TJ
Devils Lake, MI
2021 Jeep Gladiator
Bean Counter
biodiesel
New Mexico
Jeepmonster
Socal
2020 JTR, 1968 Chevy C10
I made changes over time. I have the factory Alpine system. Each change made a noticeable difference. Armorlite flooring made a noticeable difference as well (less road/suspension noise, tighter bass response). Very happy with what I have.
Terra Acoustic dash speakers.
Jeep Gladiator Sound System Upgrade 20230630_184248
Alpine R-S65.2 knee panel speakers in Metra pods with sound deadening and poly fill. The little tweeters don't do anything, as the factory amp only sends mid range frequencies to these channels.
Jeep Gladiator Sound System Upgrade 20220820_100918
Alpine SPV-65-JLT sound bar speakers.
Jeep Gladiator Sound System Upgrade 20210115_114134
Kicker Comp RT 10 inch sub in custom box (sealed) with Kicker CXA800.1 amp (behind rear seat).
Jeep Gladiator Sound System Upgrade 20210225_084411
One of my next projects will be to build a larger enclosure and replace the factory plastic bin.
