99ls1tj
My thoughts exactly, but I have about 8.5k miles on mine.I only have a little over 800 miles on mine so I don't have much experience. But here's my opinions of it.
The gas mileage is good if you keep your foot out of it and go 65mph or below on the interstate. At 60-65mph I can average around 26-29mpg, depending on how hilly it is. Now, at 80mph it drops to 17-18mpg. As for range, I'm getting around 300 miles out of a tank before the light comes on. It usually takes about 15-16 gallons to fill up. However, I do accelerate rather quickly from a stop and usually cruise at 80-85mph on the interstate. Also the diesel comes with an 18 gallon tank over the gas having a 22 gallon tank. So that would also factor into the range.
I honestly wouldn't buy a diesel for cost savings. You have to factor in more expensive oil changes and routine maintenance, the cost of diesel vs 87 octane gas, and DEF. Diesel around where I live is more expensive than 87 octane... As for DEF, I have about 65% left and it came with 75% from the factory. So I don't really know how many miles you'd get with a full tank of DEF. Then the oil changes are probably twice as much as the 3.6L.
As for the good, it has a lot of power. It pulls great with half throttle and is a blast to drive. It'll hold 8th gear on the interstate without any issue on inclines and no matter how fast you're going. It doesn't even compete in the same ballpark with 3.6L in terms of power...
POWER is the reason you should buy the diesel. I feel as though the 3.0L diesel is the PERFECT engine for the gladiator. I'm just hoping that it's somewhat reliable up to 100k miles... but I'm not too optimistic after reading all the complaints.
Anyway, would I buy the diesel again? HELL YES. The 3.6L pentastar wasn't even on my radar. It's a dog of an engine and you have to rev it too high to get power out of it. I did have an overall bad experience with the 3.6L in my 2014 JK, so that probably factors into why I dislike it so much. Honestly though, I wouldn't even have considered the gladiator if the diesel wasn't an option.
My only complaint is the bottoming out issue. I drive a lot of rough dirt / gravel roads and I have this problem quite frequently. I’m planning to do a lift soon, and hope it will fix the problem.
