Glad_he_ate
Mexico ny.
Union electrician
Immmm not gunna try it. Oh come on try it…. I’m not gunna try it …hey let’s get billy he’ll try anything!!
CrazyCooter
Tony
Far NorCal
Specialty Off Road Shop Owner
I was going to call Cold Case again and actually press them for some kind of tech data, but they are on the east coast and closed. Can you trust a cooling system builder from the east coast where there are no heat issues? ?
https://www.coldcaseradiators.com/product/18-20-jeep-wrangler-jl-aluminum-performance-radiator
All these guys gotta do is get one of us technical guys who load their truck in temps 110°+ to report our results here and they would sell dozens immediately (Assuming the findings are favorable). Where are the You Tube influencers that get the free shit when you need one? Makes me think they wont do any good........
rharr
Tucson, AZ
doesn't the ERG have some sort of taps on it that push coolant through it? Can you just splice into that tap add a deraler hyper cooler to the outlet side of the egr cooler and bring the coolant temps down before it goes back into the radiator? My thought is the egr or turbo is what is getting nailed and can't shed heat fast enough.
Anyone have a coolant system diagram or oil system diagram? that would go a long way to help understand the systems and look for solutions.
Almost
Shawn
New Jersey
2022 JTRD & 09 JKU
Until you see someone mount an aux oil cooler in the bed trophy truck style there will be no fix. Although I still suspect those that deleted no longer have overheating issue.
Deleted member 47279
deleting doesnt solve the problem. still get hot during full send. happened to me at 8000 feet at 80 mph on a steep grade.
Jefe1018
NV
It's only ugly when it isn't paint matched? jk... it's ugly.. but will it work?
Edit: not compatible with 392 or mojave models, which means it won't work with ours because of the unique cowls.
diesel has unique cowls?
Jefe1018
NV
Yep, I learned it when I went to buy the oem cowl light mounts. Diesel has the same ones as the 392 JL and Mojave JT.
Jefe1018
NV
brah, you saved me from even considering this lol
Hey we have to rely on each other to recall useless information to 99.99% of the world.
av8or
Adrian
AZ
Gladiator Overland ecodiesel (wifes)
sentient livestock transport
I don't believe that's true, got the gravity 6 bar with mounts for wifes overland diesel and they fit just fine (and are listed as not for the 392 or mojave)
Escape.idiocracy
Rich
PNW
Jt
Hitchhiker
Pretty sure this has already been done and they are different part numbers.
Funny how we're just going full circle again in these threads without a solution.........If it were an easy fix, the engineers would have done it at the factory and gave it a 8,000lb tow rating to beat everyone else in the segment.
There has to be some similarities to gen two and gen 3.
This bypass kit changes the filter element & cap of the gen 3 to a gen 2 to provide a bypass solution.
https://insanediesel.com/collection...gler-3-0l-ecodiesel-bypass-oil-filtration-kit
