Rotor Puller advice
Delhux
Boston, MA
I’ve been attempting to get to my front right wheel speed sensor for the past week, but have been stymied by a seized-on rotor. I live in the coastal northeast and everything here rusts like crazy.
After doing all the typical stuff (PB Blaster, hammers, torch, bolt through the caliper mount, etc), a rotor puller is my planned next step.
I haven’t used one before, so I am just looking for any general advice on using the puller from anyone who has done it before.
Right now, my plan is to heat up the rotor, let some PB Blaster soak in after the metal has expanded a bit, then use a rotor puller attached to my impact wrench with a few lug nuts in the studs to avoid having the hot rotor clock me in the face, and probably run a ratchet strap across the puller to limit the chance it pops off under strain (Maybe even tie a line on the cross bar of the puller, in case it does pop off).
Open to recommendations…
Vtur
Le
Norcal
JTOD
Electrical Foreman
Probably easier to just pull out the axle with it, then place the wheel studs end on the floor and hit it with a hammer.
fourfa
CA
22 JTRD + ACCC
Beware, the little torx bolts securing the rotor to the hub are soft. The Torx splines came off one of mine like butter. I managed to get it loose with a screw extractor, then omitted them on reassembly
Chance575
Chance
Earth
Diesel Jeeps..and a bunch of other junk
Trash collector
Yup heat beat and repeat
Gatorized
ME/NH
. This would probably just pop the studs out…
I had this same issue years ago - seemed like the rust/dust from the vented rotors settled around the hub and welded the two together… I heated the hub and used the bolt to apply pressure to the rotor while I rotated the rotor and beat it with a hammer. This with the vehicle on jack stands in a gravel driveway. Not fun but it eventually popped off. What really sucked was when I thought I was making progress- could see that the rotor was moving - only to discover that the rotor had a crack and the movement was just the flex opening the crack up…
Chance575
Chance
Earth
Trash collector
If you write off the rotor and are going to replace it, I know of no match to my snap on air hammer at 125 psi
You can remove the speed sensor without even removing your wheel. Tiny single bolt. M6 I think. It gently pulls out towards the inside of the vehicle. I think m6 Allen. But regarding the rotor, it depends on whether you want to replace them. Heat is great for the rotor retaining bolt. After that, put it back in with good copper anti seize. It’ll never bother you again. Tap the front of the rotor very hard with a dead blow. If that isn’t enough, 5lb sledge with wood together pretty easy protect the rotor. All the way around the rotor’s circumference until it pops off.
Delhux
Delhux
Boston, MA
You can remove the speed sensor using a long ball end Allen without removing the rotor.
Did you remove the Allen bolt holding the rotor to the wheel bearing?
If the speed sensor can actually come out with a long ball end 5mm allen, that would be great.
Yes, I took the retaining bolt off…
I’ll still be doing new brake pads and rotors before the end of the summer, regardless. So I will be using the puller and can share results after (sooner if the long Allen key doesn’t work).
If you haven’t lived on the sea coast in a region with harsh winters (like the northeast coast) —the combination of winter road salts and year-round salty air consumes all things metal. I usually reference the fact that our gas meter gets replaced every 7 years and the guys doing the work always comment that 30+ year old meters in abandoned, inland homes look better.
Salt is rough. I was in FL for 19 years. Rotors get stuck like they’re welded on.
Sweetums
Utah
Same with wheels to the rotor face, I put a smear of antisieze on the face before bolting the wheel on.
Very good advice. I swapped my rotors to aftermarket ages ago. The zinc coating is so good I never have any issue anymore. But one or oem similar are terrible.
