Diesel Engine issue tracking thread... also please post if NO issues!
Has your EcoDiesel Engine had any critical issues?
  • My CP4 pump has failed, accidentally let vehicle run out of Diesel causing air ingestion into supply
    Votes: 0 0.0%
  • Total voters
    275
Dakota Kid
North Dakota
‘21 Gladiator Willys 3.0 Eco Diesel
Pro Snipe Hunter
Did you have any issue in that cold of weather with the Diesel not getting up to temperature? Did you consider a radiator soft cover?
So sorry for missing this when you posted it! No, no issues getting up to temp and producing plenty of heat for cab.
M390
TX
2021 Gladiator Sport Ecodiesel
22K now trouble free
Hotshots EDT every fill up starting at about 5K miles
jeepin48
Jake
Michigan
JT Overland 3.0L
Service Electronic Throttle Control every time I tow my camper. This is not heat related as it happens with oil temp below 240 and it requires a key cycle for it to clear but CEL remains for a while after.
Rocco
Wheat Ridge, CO
JTRD 2021
Following up here - Dealer did a forced regen and said it's good to go now. Not sure why it didn't do the regen naturally as it's been doing the past 21k miles.
They also mentioned it was my fuel filter that caused the issue and that they were going to charge me $ for the regen for not having replaced it proactively.
BUT, when I told them it was replaced 7 weeks/3500 miles ago and they said ok, the regen is covered under warranty.....but when I asked them if they replaced the fuel filter. They said no.:whatsgoingon:
Who knows. Just happy to be on the road now as I'm driving from NC to Utah and I'm currently at Limon, CO.
I got this service message 3 hours from home in rural Kansas and limped home to CO. Maybe it has something to do with the air in Kansas? The truck is less than a year old with 23k miles. The dealer I bought it from didn't have a service appointment until the middle of next month. I found another dealer that has an appointment next week. Any explanation from the dealer on this issue? Has the truck been good since? I am feeling less confident about the reliability of this engine. I also replaced my fuel filter right around 20k which was about 3000 miles before the issue.
omgoddard
Jordan
Charlotte, NC
2021 DJTR, 2013 JKU
It does sound very familiar but it would seem really weird for air in Kansas to cause it. I mean, crazy things happen, but would seem hard to prove.
For the fix, check this thread
https://www.jeepgladiatorforum.com/...t-with-my-ecodiesel.59989/page-2#post-1016371
They replaced a component on the exhaust system. I’ve taken it on some 6 hour trips since then, 3500 miles or so and all has been good!
Rocco
Wheat Ridge, CO
JTRD 2021
I was half joking about the air in Kansas, driving through that state sucks. I am curious to see what they do to fix it and thanks for the info on the repair.
I get my worse fuel mileage in that state. I've taken a '13 GC, '08 Power Wagon, '11 Nismo, 41ft class A motorhome, and my JTRD through that state multiple times. I hit the state line and watch my mileage drop. I get into Co. or Mo. and it goes up.
jc99
jc
Vancouver
2021 JTRD
I didn’t get a parts list. They said the housing is back ordered 4 to 6 weeks. They were going to try “vehicle off road” status to make it a high priority but said it probably wouldn’t help much. What I find odd Is they said there was oil all over the place so the die test had to be done two times. I say that’s odd cuz I don’t loose any notable volume even after several thousand miles.
@Glad_he_ate Did you end up getting your oil filter housing/cooler replaced or did you end up getting rid of the Gladiator?
Diesel Sting
Billy
Apex, NC
2021 Gladiator Rubicon Diesel
20K trouble free miles. 2 regular oil changes, 1 fuel filter change, 1 air filter change. 19K of those miles have been on 37's.
Glad_he_ate
Mexico ny.
Union electrician
IPRoutes
Las Vegas
JT Mojave-X 2024 Bright White
Sr. Network Architect
Slightly off topic but do you have the 37s on stock 3.73s gear ratio or did you regear?
Zybane
Zybane
JTRD
Military Pilot
Still haven't seen a Gladiator Diesel failure that used lubrication additives. So maybe that is the key.
CreepyJeepy
Denver
2021 Jeep Gladiator Rubicon 3.0
Cyber Security
There is one guy in another thread who found metal in his fuel filter, and uses additives regularly.
it hasn’t blown fully yet, but we will know more late this week.
RhinoJT
Encinitas CA
2021 JT Ecodiesel
USMC Pilot
12234 miles and no issues so far. Started using Hot Shots EDT around the 8k mark. Changed fuel filter at 10k.
