Gladiator fuel overflowing.
WetWilly
George
Crystal River, Florida
2022 Gladiator Willys
Retired bum
Make that TWO perfect JTs.
My 2020 didn't do it but that once and it was the station's stupid nozzles. It was a "low maintenance" place, you could tell, or someone didn't know how to configure their pumps/nozzles.
Like I said - the internet is where people come to gripe about problems......... and from this forum, there aren't all that many that do the splash-back thing. Only a few in the grand scheme of things, compared to the total number sold.
(if you look into how gas pump nozzles work, most of the blame rests with the nozzle.)
I will get an official count and let you know.
Blade1668
Darrell
N. AL.
My 2020 only does it if I'm at some gas stations or I over fill it. ?
Mball488
NC
Military
I'm that person that listens to the sound of the fuel going in and stopping it as soon as it makes that "I'm about to overflow" sound. I have not been to a single pump station that has a nozzle that stops when it should. I know its 100 percent the Jeeps fault, but at this point I have gotten so use to it.
Bonanza
Southern CA
Sport S Max Tow Punk'n
Mine leaks gas out of the gas cap area as well. 2020. Not much but you can tell it happens, and leaks onto the paint.
homerun
Fort Collins, Colorado
I don’t know if you read the whole thread or if my issue was the same cause as you, but had the problem 100% of the time and the service tech found a breather hose had come loose. Reconnected it and now I only have a problem about 10% of the time I fill up. Hope that helps you.
drewcnit
Andrew
Near Nashville, TN
2022 Gladiator Sport S, Bright White
IT Geek and Data Nerd
Mine only ever puked gas before I got it lifted... Never once since...?
Grattan Township
2021 Mojave Gladiator, 2012 jeep wrangler 2 door
How’s it going guys and girls. Just got a gladiator Rubicon. Is anyone else out there having a pretty good amount of fuel overflowing when the tank fills up while pumping gas.?. I know the Jeep Has warranty but like many of us I like to avoid the dealer whenever possible. I know some jeeps in the past have had this issue but has anyone had it with a new models?
2021 Mohave, everytime, have to listen to avoid Splashdown!
Well add me to the club. My third Gladiator and first time noticing it. Seems to spit worst when refueling under a 1/4 tank left and out onto the paint side. Most other times it is a dribble that stays in the fuel door cubby area.
Iowa must have very different pump nozzles maintained differently. Gladiator #2 and no issues filling (and I almost always run down to 1/8 tank unless travelling across the country)
The only time I've had any issue was being dumb and trying to see how much more I could get into it after the nozzle kicked off, and with the 2020, it did kick back on time - with a nozzle at a station I'd not been to before. When it shut off it kicked back.
It seriously makes me wonder about some stations and their nozzles and maintenance, or if there's a vent or hose in some of these that's out of whack.
I can see things being an issue if the nozzle shields the filler neck so well as to keep air from escaping at a good speed and the gas comes out fast, building pressure in the tank until it finally burps out. I usually don't run the nozzle on full speed if I think it's coming out a bit TOO fast, I tend to watch the pump meter and have noticed some kick out fuel at a crazy rate while others on full open aren't so fast.
If the gas going in goes in so fast it builds up pressure - I could see where the gas would burp out after while when the pressure overcomes the weight of the fuel going down the tube and over to the tank on the other side.
zx5go
Southwest MO
2023 JTR
My new 2023 JTR does it. Every fill up. Even when listening I still cannot get it off fast enough to keep it from overfilling.
4xjeepr
DON
Thomasville, NC
20 Gladiator Sport, 06 Wrangler Unlimited Rubicon, 95 Wrangler Rio Grande
2020 Sport S and have never had this issue come up. Filled up or topped off at multiple stations and not one instance so far. Imagine I must be in the minority on the count.
Idlethunder
Oklahoma
2022 JTR, 23 JTRD
Manufacturing
My 22 has never done it and I'm ashamed to say I’ve been down to E a few times. For the most part I fill up at the same couple of local establishments but overall have gotten gas at 10 to 15 stations in several states
Mr.Wilson
Adam
Northern NY
Gladiator and a JL
My 2022 JT and my 2021 JL both puke gas up when I’m filling them.
