Gladiator fuel overflowing.
Phljeeper
Paul
West Chester, PA
I work
I spoke too soon. Mine just burped for the first time. I have 9000 miles and it burped fuel all over the side of my truck. Hope it’s just a one time thing.
homerun
Fort Collins, Colorado
Any chance this might be related to colder temperatures? Seems like most of us were fine all summer and only now having the issue. You think the winter fuel blend could contribute? I have no idea just spitballing here.
Moabite
Moab
2020 JT Rubicon
I have 3000 miles on mine and it never spit up gas until a couple of weeks ago. I always let the auto shutoff determine the amount of gas I put in. However, the pump recently started shutting off before the tank is full, and when I try to put in more, it immediately spits up gas. The gauge reads close to full, but not full, and there's not a chance that I'm only using 1.5 gallons of gas on a 60+ mile round trip to town. Seems like a design flaw if so many are having issues.
bgenlvtex
Bruce
Texas/Alaska
2020 JTR
Next time crank it up and see if it will take more. This sounds like a purge valve problem
Gatorized
ME/NH
Is there a test that can be used to verify the purge valve is not working?
PyrPatriot
Kentucky, USA
Had a similar concern.
https://www.jeepgladiatorforum.com/forum/threads/fuel-tank-capacity-low-fuel-light.24554/
KMal618
Keri
Cumberland, RI
2020 Jeep Gladiator Sport, 2014 Jeep Wrangler JKU
Yup! Happens with every fill, even with the nozzle all the way in. Super annoying.
Ramy
Ramy
Ramy
Miami
2020 gladiator Rubicon
This is super annoying guys I hope someone can find a solution soon. Gas spilling all over the side on every fill up will destroy the paint eventually.
it’s mind blowing that a 60+ thousand dollar Jeep has this problem.
I’ve been just adding gas until it’s almost full to avoid the issue.
Choj
Wisconsin
2017 JKU Rubicon
Record it with your phone and post it so @JeepCares has more info on this.
TrailHiker
Denny
2020 Jeep Gladiator JT Sport S, Black 1946 CJ 2A
Try pumping the gas at a slower rate, I set the pump to the slow first auto Mitch, and have never had it overspill. If it is spilling out, you are pumping the gas too fast.
Cheers
JeepCares
JeepCares
Auburn Hills, MI
Jeep Family
Customer Care
Thank you for tagging us, Choj.
Hi everyone,
For those of you experiencing this, have you had the opportunity to have your dealers take a closer look? Please feel free to PM us. We would be happy to connect you with a Case Specialist.
Alex
JeepCares
Skyler7381
Skyler
Washington
2020 Jeep Gladiator Granite LE
I've had this happen one time. Usually I just let it fill till it stops and this time it just didn't stop for about a second too late, spilled gas right down the side, not a lot but enough to piss me off.
DHP
Heath
Nashville
Overland JT
Adding in my experience to the thread. This has always happened on mine even in the summer if I tried to top it off more after the first auto cutoff. But today it did it right when the gas pump cut off. 51 degree temps today when this happened.
Gatorized
ME/NH
Is the consensus that a slow fill will avoid the overflow or that nothing seems to prevent it?
