LOGS
MN
2005 LJ Rubicon
Anyone use the new 25th anniversary grille yet?
OrangeCJ
WA, USA
1971 CJ5, 2021 JTRD
Didn't someone already do the hood removed, hood vent, grill removed drill? I thought that it yielded very little change in oil and coolant temps?Have to start re-reading... 59 pages is a lot.
22EcoDs
NY
Yes, it made minimal difference.
I opened up the Rubi hood vents. No difference on the highway. It might have helped on the trail some.
Burghardphotography
Nick
Portland, Oregon
www.instagram.com
'22 JTRD, '65 MBZ 220s, '66 Riviera GS, '72 F-250
Finding the will to live
Just chiming in to say was quite surprised in how the Tazer’s max radiator fan speed has helped in high oil temp conditions. Haven’t had a chance to try it in warm weather yet obviously, but when snow wheeling through deep powder I saw oil temps at 240ish. Kicked on that max fan mode and temps dropped 20 degrees within minutes.
I wouldnt expect that same level of results during the summer, but I’m curious to hear if anyone has tried it?
azaustin
Willliam
Lake Havasu City Arizona
2021 Jeep Gladiator Rubicon Diesel, 2014 Ford Edge
Not familiar with Tazer radiator fan. Is this an aftermarket part?
22EcoDs
NY
It's using the tazer programmer to enable the fan on high mode. If you haven't heard of one lookup tazer JL.
azaustin
Willliam
I have heard of it, but wasn’t if it was the same thing. Also not sure how it might affect my warranty. Thanks.
OrangeCJ
WA, USA
1971 CJ5, 2021 JTRD
Two Thumb Salute ™... pushing the two arrow keys to active the fan is an awesome feature with the Tazer, but we still need more cooling power on those 95+ degree days.
Always remove the Tazer out of your truck before taking in for service...they cover that in the instructions for the Tazer as well
@californiajeeping
The tazer cooldown mode helps on hills if you enable it prior to the hill. It only works under 60ish. Above that I don’t notice any difference. Someone should program the fan to auto kick on when oil temps get above 240.
azaustin
Willliam
That answers my obvious question as to when/why the fan goes to full speed.
azaustin
Willliam
After re-reading a lot of the posts. on this subject it looks like the only thing that will solve the problem is some kind of accessory oil cooler (probably with a fan.) The question is, due to the relatively low volume of diesel Gladiator. production, will anyone build it? Can it be done in such a way that it will not void the warranty? Even if it were relatively expensive (say $1500-2000) I would buy it. I really like my Gladiator and have. learned to manage the temperatures when. towing my 5,000 pound travel trailer. It would be the perfect vehicle for my purpose if the oil temperature problem could be solved.
CrazyCooter
Tony
Far NorCal
Specialty Off Road Shop Owner
This is the $15,000 warranty claim question/answer!
Chief_jeep
Park City, UT
2022 Gladiator Ecodiesel
Real Estate Agent
How did you get your tazer to do that? I'm not seeing this as an option or maybe I'm just missing it.
Can you do this while driving or only while you are parked?
