LordEnzo
Central Florida
2020 Jeep Gladiator Sport S Max Tow
Got a set of afe intake tubes. One more step towards giving water methanol injection a try. Maybe next month.
Would love to hear of ur overall results with methanol injection. I was recently starting to think if it would help somewhat with cooling as claimed. And that fact u can use 32° blue washer fluid for cheap is nice.
1is2many
andrew
Sin City
2022 gladiator rubicon diesel
Construction Planning Supervisor
Go to the right and go to min max log and let us know what your turbine inlet temp max and your MAT or manifold air temp is.
You can also see your max boost and everything in one screen.
So far doing 0-110mph runs with my derringer set to 6 on flat ground at 80 degrees i have seen:
ECT 248
EOT 253
TIT 1564
PSI 30.8
MAT 375
Very high temps. With the derringer set to stock it does keep the EGT/TIT below 1500. The rest of the temps stay the same.
ok I finally did take the pics of the min max screen.
Jeep Gladiator Diesel cooling options and ideas B4C6A137-AFDD-4866-9610-25C2DBC467D5
Jeep Gladiator Diesel cooling options and ideas 8B94AC36-0DE1-4D45-A676-C189C0108C99
Jeep Gladiator Diesel cooling options and ideas 0B803E0E-654D-4937-A4DA-5FA58A6840E8
Jeep Gladiator Diesel cooling options and ideas 30AF0061-2AC4-4083-BB70-7F5B3B1771AC
Jeep Gladiator Diesel cooling options and ideas D3EB93EB-1DAE-493D-A7DB-F6AA1DDC0071
Jeep Gladiator Diesel cooling options and ideas F3560DB8-97B1-4AE3-A7FD-E6AEB9756097
Jeep Gladiator Diesel cooling options and ideas EC030D60-C3BE-45EF-BF96-516444E6D52C
BlueScapegoat
Trevor
MN
91 ST185, 04 Ram SRT10, 04 Forester XT, SC'd 05 Rubi, 22 JTRD
Air Traffic Controller
I think at some point I've read through this whole thread, but I'm not sure. Anyway, I know that they already made the grill openings wider on the Gladiator, but I feel like they really could have gone further. The larger openings only look more aggressive to me, while keeping the factory look.
Well, here it is way bigger. 24% more opening, to be precise.
I wish I had the equipment/knowledge to manufacture stuff like this. Just slightly exaggerated OEM parts. Maybe there are legal boundaries to that. I think there's a market for it in general, across the automotive industry. But instead we get angry birds grills.
Jeep Gladiator Diesel cooling options and ideas PXL_20220630_155941806
Jeep Gladiator Diesel cooling options and ideas aggressiv
22EcoDs
NY
Good photoshop, I've thought about gutting the grill between the headlights, and creating a mesh or expanded sheet grill that has the slots painted, same effect. I don't believe it needs much rigidity.
Jeep Gladiator Diesel cooling options and ideas 1656618171804
BlueScapegoat
Trevor
MN
I should be clear that I don't condone this, but just for the hell of it:
Jeep Gladiator Diesel cooling options and ideas aggressiveanddum
:CWL:
jsalbre
Jeremy
Idaho
‘21 Sarge Mojave, ‘21 VW Tiguan SEL-P RLine
Security Engineer, First Sergeant
Funny, I was just typing out that very suggestion when it popped up that there was a new post.
That should help, but you really need more radiator surface to make much of an impact.
jsalbre
Jeremy
Idaho
:CWL:
It definitely looses some “Jeep-ness”, but it’s not nearly as bad looking as any aftermarket grille you can buy right now.
krweatherl
Ken
Kelso Wa
2022 JTRD
Heavy Haul Truck Driver
I like that, looks more like the mb.
Jeep Gladiator Diesel cooling options and ideas 12EB0DED-79DF-41D7-AD6D-66890A620F36
Someone needs to make that.
@californiajeeping
22EcoDs
NY
:CWL:
This actually doesn't look bad to me, especially if there were 6 painted lines to make it jeep certified lol. Thanks for scratching that itch.
LOGS
MN
2005 LJ Rubicon
I think someone ran without the entire front and it didn't make much difference. Personally I think we don't have enough surface area just for a good cooler. If it can't be bigger, it should be thicker and bar and plate.
ZoneArc
21 Gladiator
Manager, Solutions Consulting
It's not the grill. It's been tested. People have pulled them off completely, went back to tow, and had the same engine and oil temps.
rharr
Tucson, AZ
Has anyone ran a thermocouple on the radiator to see what temps it is and what temps the ecu is reporting.
There is a possibility it's not a radiator issue but another component (EGR cooler) that is triggering high sensor temps.
First step is to verify the radiator and the ecu reported temps are in sync.
BlueScapegoat
Trevor
MN
Which makes a lot of sense to me, I bet if you opened the whole grill up and ducted it to the radiator your limiting factor would be extracting air from the other side.
Removing all the grill including the surrounding material would be detrimental, the air needs directed, not allowed to hit the resistance of the grill and the high pressure area in front of it, and flow around.
But something like the larger slot grill at the front with tight ducting, a better aluminum radiator, and a reverse cowl hood would all work quite well together I think.
